dougdotcom Occasional Visitor
Posted: Mon Sep 05, 2005 10:53 pm Post subject: Still not locking onto satellites |
not too smart with these sat navs, So can anyone tell me why its so hard to lock onto satellites ? The other day i drove 88 miles before it locked onto any satellites, they are showing up but it never locks onto them. I run a navman with a compaq pocket pc running tom tom 5. Ps.. when i ran tom tom 3 it locked onto satellites in seconds and stayed locked on. |
stevei Lifetime Member
Posted: Mon Sep 05, 2005 11:07 pm Post subject: |
Is the GPS receiver Compact Flash, Bluetooth ot Hardwired? _________________ Steve I |
Posted: Mon Sep 05, 2005 11:17 pm Post subject: |
this is the unit im using and the screen has the settin i use to work it, >>
Posted: Mon Sep 05, 2005 11:35 pm Post subject: |
Also is this normal to have all the satellites in a line from north like this.?
Posted: Tue Sep 06, 2005 1:13 am Post subject: |
There ya go, sat in truck for 20 mins watched as more sats connected, then all of a sudden it locked onto five sats, left it for about 5mins then turned tom tom off as i have been told to do, then switched everything off, left it for 5mins switched it back on selected tom tom, went to check for a lock on and... took only 5 sec to lock on with a full siginal from 5 sats, have to see if driving round town etc tomorow works out. A big thank you to all who helped, I may still need you tomorow if things go wrong. |
lbendlin Pocket GPS Staff
Posted: Tue Sep 06, 2005 1:51 am Post subject: |
dougdotcom wrote: | Also is this normal to have all the satellites in a line from north like this.?
you see this effect when the base tables are corrupt or mising. Allow 12+ minutes to load them again. _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Tue Sep 06, 2005 6:45 pm Post subject: |
Went out for a drive today, connected the sat nav in windscreen bracket and switched on, drove for about half a mile to post office, no lock as yet, waited outside post office then a lock on three sats, thought... this is fantastic it works! drove round corner, lost connection it never came back, had to turn sat nav off and back on again then wait another five mins for it to lock onto the sats, then after about two mins it looses the sat lock again. it's like the recever wont hold onto the sats for more than five mins before it disconects. This is the post code for my area NG16 4FX so as you see there should be no problems with a week siginal, can someone please help me with this as tom tom 3 worked fine but it was just a bit out dated. |
Posted: Tue Sep 06, 2005 6:50 pm Post subject: |
TTN5 seems to try and re-initialise the receiver when it thinks the reception is bad. Not very helpful especially with older receivers that take longer to initialise. _________________ Lutz
Posted: Tue Sep 06, 2005 8:07 pm Post subject: |
What if i re-install TTN5 do you think this will help? or should i go back to TTN3 I dont want to go back if i can sort this problem out as the new version has so much more going for it. getting fed up now. |
Robin2 Lifetime Member
Posted: Tue Sep 06, 2005 8:10 pm Post subject: |
Try holding the receiver outside the car while powered up and see if it gets a fix quicker. The reflective glass in some windscreens degrades the signal
Robin _________________ TomTom One v3 Europe, Navcore 7.903, Western Europe 835.2420
Satmap Active 10
Plus a lot of other PDA GPS kit, seldom used |
Posted: Tue Sep 06, 2005 8:44 pm Post subject: |
Just a thought...I have the satnav in a pajero, these have a pod ontop of the dash with a digital compass and two other displays could it be interfering with the satnav? should i place it to the right of the dashboard where there are no parts with power going through them. then again it has been sat in my window bottom at home and had a lock on three sats and only held onto them for about 5 mins before loosing them. I would say the signal strength before it lost the lock was about 70%. Is there any way to increase the gain to boost the reception? |
Posted: Wed Sep 07, 2005 3:36 pm Post subject: |
Can an external aerial be fitted to my navman?
[/quote] |
Posted: Wed Sep 07, 2005 7:30 pm Post subject: |
Just got home from a 5 mile trip and it never lost the sat lock, do you think that the more i use it the better it gets? I remember when i used tom tom 3 that took a while to settle down. moto..."the more you use it the better it get's" |
Steveee Lifetime Member
Joined: Dec 16, 2003 Posts: 203 Location: Colchester, Essex
Posted: Thu Sep 08, 2005 12:48 am Post subject: |
Just a small suggestion but have you checked that the infrared is turned off on the iPaq?
I know that the navman sleeve (I think the iPaq sleeve is a rebadged navman) needs the iPaq infrared turned off as it interfers with the receiver. Sudden changes in brightness cause the receiver to loose satellites. I know this from bitter experience! _________________ Steveee
Where am I?
GO 920 (retired)
Garmin Oregon 550T
Garmin Drivesmart |
