Pocket GPS World :: View topic - POI Extended Warning Sounds & Text
Goto page Previous  1, 2
rkm_hm
PostPosted: Wed Sep 07, 2005 2:28 pm    Post subject: Reply with quote
Many thanks, Ray - I'll give it a whirl!
Roger
TomTom via135
Satmap Active 10+ v1.50 with full UK 1:50k map and 1:25k/1:10k County maps of Hampshire & Warwickshire
PostPosted: Wed Sep 07, 2005 6:39 pm    Post subject: Reply with quote
Just a side note. Not all OGG files in a given DATA.CHK are usable, some of them are compressed/encrypted. But that's not much of an issue since you want to replace them anyhow. ( It only becomes a slight issue when you want to convert a DATAxx.CHK file back into WAV files for TTN3. But again that's mostly academic).
I hope everybody is aware that this tool will have to be used again when you are upgrading to newer TTN versions.
wez99
PostPosted: Thu Sep 08, 2005 8:34 pm    Post subject: Reply with quote
Thanks for the app Ray,
Just one question, When a text message is recieved on my 700, it gives a "mobile" warning. Do you happen to know whether it is possible to isolate the warning and give it a sound of its own?
John
TomTomGo730
rkm_hm
PostPosted: Thu Sep 08, 2005 9:51 pm    Post subject: Reply with quote
Thanks again, Ray - it works like a dream. I'm now the proud owner of a unique set of warning sounds!
When I next upgrade the firmware on TTG, do I simply have to extract the ttn file from ttsystem in the new version, and use it with my existing (modified) data.chk file to produce a new ttn and data.chk? Hopefully the program will remember the current text descriptions and .ogg files - so it should only be a 5 minute job?
Roger
TomTom via135
rayflan
PostPosted: Thu Sep 08, 2005 10:03 pm    Post subject: Reply with quote
John
Find an ogg sound you want to use for the text message save as smsreceived.ogg and put in the root of your sdcard. You can do the same for the ringtone- ringtone.ogg
Ray
New Url www.tomtomsatnav.info
Visit my site
rayflan
PostPosted: Thu Sep 08, 2005 10:08 pm    Post subject: Reply with quote
As with current warning sounds you will have to rebuild the new data.chk and extract the new ttn But the app will only work with current firmware so will have to be updated when released.
Ray
Visit my site
rkm_hm
PostPosted: Thu Sep 08, 2005 10:35 pm    Post subject: Reply with quote
I'm currently on 5.200
Presumably I could go to 5.201 by the route I suggested if I wished?
[Not quite sure what is in 5.201 that's not in 5.200 - is there anything of benefit to a Classic?]
Roger
TomTom via135
rayflan
PostPosted: Thu Sep 08, 2005 10:57 pm    Post subject: Reply with quote
Yes you can.
The program works on TTGO 5, 5.1, 5.2, 5.201, & 5.202 also TTN 5 & 5.1
If you load a file it doesn't recognize it will show " ....does not appear to be a TomTom file. "
Ray
Visit my site
PostPosted: Fri Sep 09, 2005 7:03 am    Post subject: Reply with quote
The only apparent difference is that there is a menu item in Setup that allows you to Backup the whole SD card, rather than use Explorer.
TT said there where a number of other 'improvements', but haven't found them.
TT Via 135 App 12.075: Europe Map v1135
rkm_hm
PostPosted: Fri Sep 09, 2005 8:56 am    Post subject: Reply with quote
Don't think I'll bother with 5.201 then - I always back up manually rather than relying on TT's routine.
Roger
TomTom via135
davethepitch
PostPosted: Sat Sep 10, 2005 7:34 pm    Post subject: Reply with quote
I have just tried Rays extended warnings sounds software and all i can say is excellent
rayflan
PostPosted: Sat Sep 10, 2005 7:46 pm    Post subject: Reply with quote
Anyone having problems downloading the app ?
Had a couple of reports "Can't see download buttons" ?
Ray
Visit my site
Page 2 of 2
22.111 (06 Nov 24)
