SharpEye Lifetime Member
Joined: May 04, 2005 Posts: 55 Location: Northampton, Surrey
Posted: Wed Sep 07, 2005 10:14 am Post subject: Upgrade |
Upgraded to version 4
The install whinged that I need to uninstall the old version first (which I didn't need to on the version 1 to 2 upgrade)
One for the wish list - could there be added to the right click menu the facility to stop the current update?
I have found that OTN is very tardy displaying the options dialogue whilst it is updating, and when you start the programme it immediatley launches into an update, so it would be beneficial if the current update can be stopped so that the options can be set.
SharpEye |
Posted: Wed Sep 07, 2005 10:16 am Post subject: Updating |
I like the way the system tray icon now changes when it is updating so that you know what it is up to.
SharpEYe |
SandyMac Occasional Visitor
Posted: Wed Sep 07, 2005 11:27 am Post subject: |
Pete,
Thanks for responding. The overlay files are there but TT5 doesn't show them as an option to tick. Have tried reducing the amount but still can't see it. As I said CheckPOInt sees the POI. Don't know what else to try.
Any help gratefully received.
Sandy |
Posted: Wed Sep 07, 2005 11:38 am Post subject: |
Sandy
Have you tried the basic stopping and starting of TT5? Failing that a soft rest of the PPC?
I find using TT3 that it does not like the files to be altered whilst it is running, so I exit TT3 before placing it on the cradle.
Make sure that you actually exit the program and not just use the "x" in the top right hand corner of the window. That X just closes the window and leaves TT3 running
SharpEye |
Posted: Wed Sep 07, 2005 12:00 pm Post subject: |
SharpEye,
Thanks for the advice. Have tried all of the above without success. Can't find any info on TT5 that would stop me seeing the POI as an option so don't know if there are any "hidden limitations" that may be causing this.
I have successfully included the UK traffic cameras etc but this one just doesn't want to show itself. A real pity as I have not experienced any problems with OTN and really want to use it.
Sandy |
gordiegord Occasional Visitor
Posted: Wed Sep 07, 2005 12:23 pm Post subject: SandyMac |
Hiya
Silly question, but u do have a viable *.ov2 file don't you? What size is it? It has successfully copied to your GB map directory intact hasn't it?
It is stating the bleeding obvious I know - but just checking!
GordieGord |
molchew Occasional Visitor
Posted: Wed Sep 07, 2005 12:56 pm Post subject: Still cannot connect to a Proxy Server |
http://www.bbc.co.uk/travelnews/tpeg/en/local/rtm/bedshertsandbucks_tpeg.xml
The underlying connection was closed: The proxy name could not be resolved, verify correct proxy configuration.
I get a number of the above logs, when I am connected to my work server. Could someone give me an example of the entries into the 4 boxes on the proxy server tab. |
Posted: Wed Sep 07, 2005 12:59 pm Post subject: |
GordieGord
Thanks for the suggestion. Always worth stating the obvious as I may have missed it. Unfortunately, the OV2 file is OK and can be seen as valid in CheckPOInt. The current size is 133KB and seems to be updating correctly. Pulling what little hair I have left out on this one as it has certainly got to be something simple(!)
Sandy |
Posted: Wed Sep 07, 2005 1:15 pm Post subject: SandyMac |
SandyMac
Do you wanna go through, step by step, what you have done so far. Start from the viable ov2 & BMP files and tell us what you did with them and lets see if there is any reason why it isn't displaying.
What hardware/software are u using? Have you tried to disable all POI's except the traffic ones to see if that makes any difference? May make things clearer and you can re-enable them later.
I just use explore via Active Sync to drag and drop the files from the XP My Documents folder to my GB map directory on my SD card and they have all worked that way. I haven't tried the CheckPOInt software as yet. |
rsutcliffe Occasional Visitor
Posted: Wed Sep 07, 2005 1:20 pm Post subject: |
molchew - proxy settings should be as follows:
URL: http://proxyservername:portnumber
Username: yourusername
Password: yourpassword
Domain: windowsnetworkdomain
If any of these aren't applicable then leave the field blank.
If you do not see all these fields then download the latest version from the delphi-dolphin url posted earlier. |
Posted: Wed Sep 07, 2005 1:26 pm Post subject: |
sandymac - I'm sure there is a better way to see the POI's on your route but I cannot for the life of me remember where I saw it (may have been TTN3, I'm sure there was a checklist where you could enable/disable the PoI's you could see).
To view the PoI's once they have been copied over to the map folder, I go into the menu and choose browse map. Clicking on the magnifying glass allows you to see various option to look for - select PoI and the next screen that appears should be the five most recently used PoI's. If offlinetrafficnews isn't one of these click the arrow to see the full PoI category list. Once selected in here you should be presented with a list of the closest traffic PoI's.
Once I've done this I can then see the PoI's in the 3D Navigator view.
Hope this helps! |
Posted: Wed Sep 07, 2005 1:36 pm Post subject: |
GoerdieGord,
Thanks for your willingness to help. I have deleted all POIs but OTN and now have visibility. Obviously there is a restriction on not just viewing but on the amount that can be selected (if that makes sense).
Very big thank you to all who helped. Knew it had to be something simple so apologies.
Good news is that I now have a fully automated traffic management system running. Just need to find the limits on POI categories and determine what I don't need.
Sandy |
Posted: Wed Sep 07, 2005 1:37 pm Post subject: Have now got connection but get this error log |
I now have connection but get the following error log
There is an error in XML document (1, 44).
The underlying connection was closed: Unable to connect to the remote server.
<?xml version="1.0" encoding="ISO-8859-1"?>
<!DOCTYPE tpeg_document PUBLIC "-//EBU/tpegML/EN" "http://www.bbc.co.uk/travelnews/xml/tpegml_en/tpegML.dtd">
<tpeg_document generation_time="2005-09-07T12:25:59+0">
<tpeg_message>
<originator country="UK" originator_name="BBC Travel News"/>
<summary xml:lang="en">M25 Hertfordshire - Very slow traffic anticlockwise between J20, Kings Langley and J17, Maple Cross in Greater London.</summary>
<road_traffic_message message_id="588251" message_generation_time="2005-09-07T11:35:45+0" version_number="12" start_time="2005-06-24T07:03:00+0" stop_time="2005-09-07T12:35:14+0" severity_factor="&rtm31_4;">
<network_performance><performance network_performance="&rtm34_3;"/><speed metres_per_second ="%Q%"/></network_performance ><location_container language="&loc41_30;">
<location_coordinates location_type="&loc1_3;">
<WGS84 latitude="51.700341" longitude="-0.443695" />
<location_descriptor descriptor_type="&loc3_7;" descriptor="M25;"/>
<location_descriptor descriptor_type="&loc3_24;" descriptor="Greater London"/>
<location_descriptor descriptor_type="&loc3_10;" descriptor="Kings Langley"/>
<location_descriptor descriptor_type="&loc3_32;" descriptor="M25; 20"/>
<location_descriptor descriptor_type="&loc3_8;" descriptor="A41;"/>
<WGS84 latitude="51.637248" longitude="-0.510669" />
<location_descriptor descriptor_type="&loc3_24;" descriptor="HERTFORDSHIRE"/>
<location_descriptor descriptor_type="&loc3_10;" descriptor="Maple Cross"/>
<location_descriptor descriptor_type="&loc3_32;" descriptor="M25; 17"/>
<location_descriptor descriptor_type="&loc3_8;" descriptor="A412;"/>
<direction direction_type="&loc2_11;"/>
</location_coordinates>
</location_container>
</road_traffic_message>
</tpeg_message>
<tpeg_message>
<summary xml:lang="en">M25 Hertfordshire - Earlier accident clockwise before J17, Maple Cross in Greater London, severe delays.</summary>
<road_traffic_message message_id="588968" message_generation_time="2005-09-07T11:37:59+0" version_number="6" start_time="2005-09-07T09:23:07+0" stop_time="2005-09-07T12:36:03+0" severity_factor="&rtm31_4;">
<accidents number_of="1"/><network_performance></network_performance><location_container language="&loc41_30;">
<direction direction_type="&loc2_10;"/>
</tpeg_message>
<tpeg_message>
<summary xml:lang="en">M40 Buckinghamshire - Debris on road northbound between J5, Stokenchurch and J6, Watlington, because of a rolling road block.</summary>
<road_traffic_message message_id="589083" message_generation_time="2005-09-07T12:23:24+0" version_number="1" start_time="2005-09-07T12:23:24+0" stop_time="2005-09-07T13:20:07+0" severity_factor="&rtm31_3;">
<obstructions number_of="1"><object number_of="1"><position position="&rtm10_37;"/><object_problem object_problem="&rtm12_0;"/></object></obstructions><network_conditions><restriction restriction ="&rtm49_1;"><condition_status condition_status="&rtm47_7;"/> </restriction></network_conditions><network_conditions><restriction restriction="&rtm49_2;"/></network_conditions><location_container language="&loc41_30;">
<WGS84 latitude="51.660526" longitude="-0.912855" />
<location_descriptor descriptor_type="&loc3_7;" descriptor="M40;"/>
<location_descriptor descriptor_type="&loc3_24;" descriptor="Buckinghamshire"/>
<location_descriptor descriptor_type="&loc3_10;" descriptor="Stokenchurch"/>
<location_descriptor descriptor_type="&loc3_32;" descriptor="M40; 5"/>
<location_descriptor descriptor_type="&loc3_8;" descriptor="A40;"/>
<WGS84 latitude="51.672388" longitude="-0.960742" />
<location_descriptor descriptor_type="&loc3_24;" descriptor="OXFORDSHIRE"/>
<location_descriptor descriptor_type="&loc3_10;" descriptor="Watlington"/>
<location_descriptor descriptor_type="&loc3_32;" descriptor="M40; 6"/>
<location_descriptor descriptor_type="&loc3_8;" descriptor="B4009;"/>
<direction direction_type="&loc2_3;"/>
</tpeg_message>
<tpeg_message>
<summary xml:lang="en">Hertfordshire - Roadworks on Hatch Lane both ways at the Chalk Hills junction in Baldock, temporary traffic lights.</summary>
<road_traffic_message message_id="1535" message_generation_time="2005-03-14T13:20:32+0" version_number="1" start_time="2004-08-02T11:07:39+0" stop_time="2005-12-28T17:45:15+0" severity_factor="&rtm31_1;">
<network_conditions><position position="&rtm10_0;"/><roadworks roadworks ="&rtm50_0;"/></network_conditions><facilities_performance><traffic_control traffic_control_type="&rtm42_11;" traffic_control_status="&rtm43_1;"><position position="&rtm10_37;"/></traffic_control></facilities_performance><location_container language="&loc41_30;">
<WGS84 latitude="51.975984" longitude="-0.185852" />
<location_descriptor descriptor_type="&loc3_7;" descriptor=";Hatch Lane"/>
<location_descriptor descriptor_type="&loc3_24;" descriptor="Baldock"/>
<location_descriptor descriptor_type="&loc3_8;" descriptor=";Chalk Hills"/>
<direction direction_type="&loc2_2;"/>
</tpeg_message>
<tpeg_message>
<summary xml:lang="en">A1000 Hertfordshire - Roadworks on Broadwater Road at the B195 Bridge Road junction in Welwyn Garden City.</summary>
<road_traffic_message message_id="123106" message_generation_time="2005-03-14T13:20:17+0" version_number="1" start_time="2004-11-03T11:41:47+0" stop_time="2005-09-13T00:14:00+0" severity_factor="&rtm31_1;">
<network_conditions><position position="&rtm10_0;"/><roadworks roadworks ="&rtm50_0;"/></network_conditions><location_container language="&loc41_30;">
<WGS84 latitude="51.802029" longitude="-0.19853" />
<location_descriptor descriptor_type="&loc3_7;" descriptor="A1000;Broadwater Road"/>
<location_descriptor descriptor_type="&loc3_24;" descriptor="Welwyn Garden City"/>
<location_descriptor descriptor_type="&loc3_8;" descriptor="B195;Bridge Road"/>
<location_descriptor descriptor_type="&loc3_9;" descriptor=";Bridge Road East"/>
</tpeg_message>
<tpeg_message>
<summary xml:lang="en">M25 Surrey - Restrictions both ways between J12, Thorpe Interchange and J15, Thorney Interchange in Greater London, speed restriction of 40 mph.</summary>
<road_traffic_message message_id="221281" message_generation_time="2005-08-25T12:32:45+0" version_number="1" start_time="2004-10-01T10:50:39+0" stop_time="2005-12-31T01:29:00+0" severity_factor="&rtm31_2;">
<network_conditions><position position="&rtm10_0;"/><roadworks roadworks ="&rtm50_0;"/></network_conditions><network_conditions><position position="&rtm10_37;"/><restriction restriction ="&rtm49_255;"/></network_conditions><network_conditions><position position="&rtm10_37;"/><restriction restriction ="&rtm49_255;"/></network_conditions><network_conditions><position position="&rtm10_37;"/><restriction restriction ="&rtm49_5;"/></network_conditions><location_container language="&loc41_30;">
<WGS84 latitude="51.400639" longitude="-0.537445" />
<location_descriptor descriptor_type="&loc3_10;" descriptor="Thorpe Interchange"/>
<location_descriptor descriptor_type="&loc3_32;" descriptor="M25; 12"/>
<location_descriptor descriptor_type="&loc3_8;" descriptor="M3;"/>
<WGS84 latitude="51.494755" longitude="-0.494257" />
<location_descriptor descriptor_type="&loc3_24;" descriptor="BERKSHIRE"/>
<location_descriptor descriptor_type="&loc3_10;" descriptor="Thorney Interchange"/>
<location_descriptor descriptor_type="&loc3_32;" descriptor="M25; 15"/>
<location_descriptor descriptor_type="&loc3_8;" descriptor="M4;"/>
</tpeg_message>
<tpeg_message>
<summary xml:lang="en">A421 Bedfordshire - Temporary traffic lights on Bedford Road both ways near the Roxton Road junction in Roxton, because of roadworks during off-peak periods.</summary>
<road_traffic_message message_id="362201" message_generation_time="2005-04-18T11:40:35+0" version_number="1" start_time="2005-04-18T10:16:51+0" stop_time="2005-09-29T15:00:00+0" severity_factor="&rtm31_2;">
<facilities_performance><traffic_control traffic_control_type="&rtm42_11;" traffic_control_status="&rtm43_1;"><position position="&rtm10_37;"/></traffic_control></facilities_performance><network_conditions><position position="&rtm10_37;"/><roadworks roadworks ="&rtm50_0;"><condition_status condition_status="&rtm47_18;"/></roadworks></network_conditions><location_container language="&loc41_30;">
<WGS84 latitude="52.181714" longitude="-0.314724" />
<location_descriptor descriptor_type="&loc3_7;" descriptor="A421;Bedford Road"/>
<location_descriptor descriptor_type="&loc3_24;" descriptor="Roxton"/>
<location_descriptor descriptor_type="&loc3_8;" descriptor=";Roxton Road"/>
</tpeg_message>
<tpeg_message>
<summary xml:lang="en">A1 Bedfordshire - Restrictions on Great North Road both ways at the Black Cat Roundabout junction in Roxton.</summary>
<road_traffic_message message_id="362298" message_generation_time="2005-07-04T13:33:47+0" version_number="3" start_time="2005-04-18T11:37:22+0" stop_time="2006-08-13T23:59:00+0" severity_factor="&rtm31_2;">
<network_conditions><position position="&rtm10_37;"/><restriction restriction ="&rtm49_255;"/></network_conditions><location_container language="&loc41_30;">
<WGS84 latitude="52.184846" longitude="-0.304878" />
<location_descriptor descriptor_type="&loc3_7;" descriptor="A1;Great North Road"/>
<location_descriptor descriptor_type="&loc3_10;" descriptor="Black Cat Roundabout"/>
<location_descriptor descriptor_type="&loc3_8;" descriptor="A421;Bedford Road"/>
</tpeg_message>
<tpeg_message>
<summary xml:lang="en">A1081 Hertfordshire - Temporary traffic lights on Harpenden Road both ways near the B651 Avenue Road junction in St Albans, because of water main work.</summary>
<road_traffic_message message_id="437580" message_generation_time="2005-06-03T10:13:19+0" version_number="1" start_time="2005-06-03T10:13:19+0" stop_time="2005-09-30T23:59:00+0" severity_factor="&rtm31_2;">
<facilities_performance><traffic_control traffic_control_type="&rtm42_11;" traffic_control_status="&rtm43_1;"><position position="&rtm10_37;"/></traffic_control></facilities_performance><network_conditions><position position="&rtm10_37;"/><roadworks roadworks ="&rtm50_2;"/></network_conditions><location_container language="&loc41_30;">
<WGS84 latitude="51.75781" longitude="-0.33354" />
<location_descriptor descriptor_type="&loc3_7;" descriptor="A1081;Harpenden Road"/>
<location_descriptor descriptor_type="&loc3_24;" descriptor="St Albans"/>
<location_descriptor descriptor_type="&loc3_8;" descriptor="B651;Avenue Road"/>
</tpeg_message>
<tpeg_message>
<summary xml:lang="en">A1 Bedfordshire - Speed restriction of 40 mph on Great North Road both ways at the Black Cat Roundabout junction in Roxton, because of roadworks.</summary>
<road_traffic_message message_id="437615" message_generation_time="2005-06-03T11:16:52+0" version_number="4" start_time="2005-06-03T10:46:54+0" stop_time="2006-08-13T23:59:00+0" severity_factor="&rtm31_3;">
<network_conditions><position position="&rtm10_0;"/><roadworks roadworks ="&rtm50_0;"/></network_conditions><network_conditions><position position="&rtm10_37;"/><restriction restriction ="&rtm49_255;"/></network_conditions><location_container language="&loc41_30;">
</tpeg_message>
<tpeg_message>
<summary xml:lang="en">A421 Bedfordshire - Roadworks during off-peak periods on Bedford Road at the Roxton Road junction in Roxton.</summary>
<road_traffic_message message_id="488382" message_generation_time="2005-07-04T13:30:57+0" version_number="1" start_time="2005-07-04T13:30:57+0" stop_time="2005-09-29T15:00:00+0" severity_factor="&rtm31_1;">
</tpeg_message>
<tpeg_message>
<summary xml:lang="en">A421 Bedfordshire - Roadworks during off-peak periods on St Neots Road at the Water End junction in Renhold.</summary>
<road_traffic_message message_id="488384" message_generation_time="2005-07-04T13:33:21+0" version_number="1" start_time="2005-07-04T13:33:21+0" stop_time="2005-09-29T15:00:00+0" severity_factor="&rtm31_1;">
<WGS84 latitude="52.1493" longitude="-0.386781" />
<location_descriptor descriptor_type="&loc3_7;" descriptor="A421;St Neots Road"/>
<location_descriptor descriptor_type="&loc3_24;" descriptor="Renhold"/>
<location_descriptor descriptor_type="&loc3_8;" descriptor=";Water End"/>
</tpeg_message>
<tpeg_message>
<summary xml:lang="en">A1(M) Hertfordshire - Speed restriction of 40 mph both ways between J7 A602 and J8 A602, because of resurfacing work.</summary>
<road_traffic_message message_id="511707" message_generation_time="2005-09-03T08:17:34+0" version_number="2" start_time="2005-07-18T11:11:03+0" stop_time="2005-10-07T23:59:00+0" severity_factor="&rtm31_4;">
<network_conditions><position position="&rtm10_0;"/><roadworks roadworks ="&rtm50_1;"/></network_conditions><network_conditions><position position="&rtm10_37;"/><restriction restriction ="&rtm49_3;"/></network_conditions><network_conditions><position position="&rtm10_37;"/><restriction restriction ="&rtm49_255;"/></network_conditions><location_container language="&loc41_30;">
<WGS84 latitude="51.887537" longitude="-0.206288" />
<location_descriptor descriptor_type="&loc3_7;" descriptor="A1(M);"/>
<location_descriptor descriptor_type="&loc3_24;" descriptor="Hertfordshire"/>
<location_descriptor descriptor_type="&loc3_10;" descriptor="Stevenage South"/>
<location_descriptor descriptor_type="&loc3_32;" descriptor="A1(M); 7"/>
<location_descriptor descriptor_type="&loc3_8;" descriptor="A602;"/>
<WGS84 latitude="51.928017" longitude="-0.219742" />
<location_descriptor descriptor_type="&loc3_32;" descriptor="A1(M); 8"/>
<location_descriptor descriptor_type="&loc3_10;" descriptor="Stevenage North"/>
<location_descriptor descriptor_type="&loc3_9;" descriptor="B197;"/>
</tpeg_message>
<tpeg_message>
<summary xml:lang="en">A600 Hertfordshire - One lane closed on Bedford Road at the Ryder Avenue junction in Ickleford, temporary traffic lights.</summary>
<road_traffic_message message_id="517770" message_generation_time="2005-07-21T12:48:18+0" version_number="2" start_time="2005-07-21T12:45:35+0" stop_time="2005-09-30T00:00:00+0" severity_factor="&rtm31_2;">
<facilities_performance><traffic_control traffic_control_type="&rtm42_11;" traffic_control_status="&rtm43_1;"><position position="&rtm10_37;"/></traffic_control></facilities_performance><network_conditions><position position="&rtm10_0;"/><roadworks roadworks ="&rtm50_2;"/></network_conditions><network_performance></network_performance><network_conditions><position position="&rtm10_0;"/><restriction restriction ="&rtm49_255;"/></network_conditions><location_container language="&loc41_30;">
<WGS84 latitude="51.968279" longitude="-0.287354" />
<location_descriptor descriptor_type="&loc3_7;" descriptor="A600;Bedford Road"/>
<location_descriptor descriptor_type="&loc3_24;" descriptor="Ickleford"/>
<location_descriptor descriptor_type="&loc3_8;" descriptor=";Ryder Avenue"/>
</tpeg_message>
<tpeg_message>
<summary xml:lang="en">Buckinghamshire - West Street closed both ways at the Addison Road junction in Steeple Claydon, because of bridge maintenance work.</summary>
<road_traffic_message message_id="544057" message_generation_time="2005-08-08T12:44:22+0" version_number="1" start_time="2005-08-08T12:44:22+0" stop_time="2005-09-17T23:59:00+0" severity_factor="&rtm31_2;">
<network_conditions><position position="&rtm10_0;"/><roadworks roadworks ="&rtm50_3;"/></network_conditions><network_conditions><restriction restriction="&rtm49_1;"/></network_conditions><location_container language="&loc41_30;">
<WGS84 latitude="51.936654" longitude="-0.990199" />
<location_descriptor descriptor_type="&loc3_7;" descriptor=";West Street"/>
<location_descriptor descriptor_type="&loc3_24;" descriptor="Steeple Claydon"/>
<location_descriptor descriptor_type="&loc3_8;" descriptor=";Addison Road"/>
</tpeg_message>
<tpeg_message>
<summary xml:lang="en">Bedfordshire - Roadworks during off-peak periods on Stanbridge Road both ways between the A4146 Lake Street junction and the Cherrycourt Way junction in Leighton Buzzard, because of roundabout construction.</summary>
<road_traffic_message message_id="561779" message_generation_time="2005-08-19T10:41:44+0" version_number="1" start_time="2005-08-19T10:41:44+0" stop_time="2005-09-30T23:59:00+0" severity_factor="&rtm31_1;">
<network_conditions><position position="&rtm10_37;"/><roadworks roadworks ="&rtm50_0;"><condition_status condition_status="&rtm47_18;"/></roadworks></network_conditions><network_conditions><position position="&rtm10_0;"/><roadworks roadworks ="&rtm50_0;"/></network_conditions><location_container language="&loc41_30;">
<WGS84 latitude="51.913243" longitude="-0.65682" />
<location_descriptor descriptor_type="&loc3_7;" descriptor=";Stanbridge Road"/>
<location_descriptor descriptor_type="&loc3_24;" descriptor="Leighton Buzzard"/>
<location_descriptor descriptor_type="&loc3_8;" descriptor="A4146;Lake Street"/>
<WGS84 latitude="51.912349" longitude="-0.639255" />
<location_descriptor descriptor_type="&loc3_24;" descriptor="LEIGHTON BUZZARD"/>
<location_descriptor descriptor_type="&loc3_8;" descriptor=";Cherrycourt Way"/>
</tpeg_message>
<tpeg_message>
<summary xml:lang="en">A4146 Bedfordshire - Roadworks on Stoke Road both ways near the Old Linslade Road junction in Soulbury.</summary>
<road_traffic_message message_id="566623" message_generation_time="2005-08-23T10:26:51+0" version_number="1" start_time="2005-08-23T10:26:51+0" stop_time="2006-05-18T23:59:00+0" severity_factor="&rtm31_1;">
<WGS84 latitude="51.929091" longitude="-0.684243" />
<location_descriptor descriptor_type="&loc3_7;" descriptor="A4146;Stoke Road"/>
<location_descriptor descriptor_type="&loc3_24;" descriptor="Soulbury"/>
<location_descriptor descriptor_type="&loc3_8;" descriptor=";Old Linslade Road"/>
</tpeg_message>
<tpeg_message>
<summary xml:lang="en">A41 Buckinghamshire - Roadworks on Tring Road both ways near the Parton Road junction in Aylesbury, because of roadworks during the night.</summary>
<road_traffic_message message_id="566640" message_generation_time="2005-08-23T10:59:22+0" version_number="1" start_time="2005-08-23T10:59:22+0" stop_time="2005-09-18T23:59:00+0" severity_factor="&rtm31_2;">
<network_conditions><position position="&rtm10_0;"/><roadworks roadworks ="&rtm50_0;"/></network_conditions><network_conditions><position position="&rtm10_37;"/><roadworks roadworks ="&rtm50_0;"><condition_status condition_status="&rtm47_18;"/></roadworks></network_conditions><location_container language="&loc41_30;">
<WGS84 latitude="51.81358" longitude="-0.784996" />
<location_descriptor descriptor_type="&loc3_7;" descriptor="A41;Tring Road"/>
<location_descriptor descriptor_type="&loc3_24;" descriptor="Aylesbury"/>
<location_descriptor descriptor_type="&loc3_8;" descriptor=";Parton Road"/>
</tpeg_message>
<tpeg_message>
<summary xml:lang="en">M1 Hertfordshire - Speed restriction of 40 mph northbound at J6, Bricket Wood, narrow lanes.</summary>
<road_traffic_message message_id="578173" message_generation_time="2005-08-31T17:01:00+0" version_number="4" start_time="2005-08-31T10:53:35+0" stop_time="2005-12-16T23:59:00+0" severity_factor="&rtm31_3;">
<network_conditions><position position="&rtm10_0;"/><roadworks roadworks ="&rtm50_0;"/></network_conditions><network_conditions><position position="&rtm10_37;"/><restriction restriction ="&rtm49_255;"/></network_conditions><network_conditions><position position="&rtm10_37;"/><restriction restriction ="&rtm49_5;"/></network_conditions><network_conditions><position position="&rtm10_39;"/><restriction restriction ="&rtm49_1;"/></network_conditions><location_container language="&loc41_30;">
<WGS84 latitude="51.705836" longitude="-0.381895" />
<location_descriptor descriptor_type="&loc3_7;" descriptor="M1;"/>
<location_descriptor descriptor_type="&loc3_10;" descriptor="Bricket Wood"/>
<location_descriptor descriptor_type="&loc3_32;" descriptor="M1; 6"/>
<location_descriptor descriptor_type="&loc3_8;" descriptor="A405;"/>
</tpeg_message>
<tpeg_message>
<summary xml:lang="en">M10 Hertfordshire - Speed restriction of 50 mph both ways at M1, narrow lanes.</summary>
<road_traffic_message message_id="578177" message_generation_time="2005-08-31T17:00:15+0" version_number="3" start_time="2005-08-31T10:57:36+0" stop_time="2005-12-16T23:59:00+0" severity_factor="&rtm31_3;">
<location_coordinates location_type="&loc1_5;">
<WGS84 latitude="51.743703" longitude="-0.400329" />
<location_descriptor descriptor_type="&loc3_7;" descriptor="M10;"/>
<location_descriptor descriptor_type="&loc3_8;" descriptor="M1;J7"/>
</tpeg_message>
<tpeg_message>
<summary xml:lang="en">A1000 Hertfordshire - Roadworks on Bessemer Road at the Haldens junction in Welwyn Hatfield.</summary>
<road_traffic_message message_id="580371" message_generation_time="2005-09-01T10:50:14+0" version_number="1" start_time="2005-09-01T10:50:14+0" stop_time="2005-09-11T23:59:00+0" severity_factor="&rtm31_2;">
<WGS84 latitude="51.810949" longitude="-0.193837" />
<location_descriptor descriptor_type="&loc3_7;" descriptor="A1000;Bessemer Road"/>
<location_descriptor descriptor_type="&loc3_24;" descriptor="Welwyn Hatfield"/>
<location_descriptor descriptor_type="&loc3_8;" descriptor=";Haldens"/>
<location_descriptor descriptor_type="&loc3_9;" descriptor=";Knightsfield"/>
</tpeg_message>
</tpeg_document> |
Posted: Wed Sep 07, 2005 1:49 pm Post subject: |
molchew - can you check your firewall settings? Try switching this off and trying to see if this is the issue (remember to turn it back on again!) |
eversonl Occasional Visitor
Posted: Wed Sep 07, 2005 1:56 pm Post subject: |
molchew,
I have the same problem..It's very odd as the fact that the xml.log is full of traffic information would make you think that it had actually worked. Yet still the ov2 file is 0k.
Richard, I think it's close but no cigar yet  |
