Pocket GPS World :: View topic - Poor Mains connection in PNA175
tel33
PostPosted: Mon Sep 05, 2005 6:42 pm    Post subject: Poor Mains connection in PNA175 Reply with quote
Just thought I would say I may have found a slight flaw in the MDPNA175 and its associated cousins..
I began wondering why my PNA175 had problems when I inserted the power or car connector into the external power socket as I had to move it around to get it to work properly and charge the unit up.
On investigation I found that the main board external power connector had not been soldered at all on the back edge, if it had been I would have been able to see it but it was solder free.
A quick but very careful solder job and the connection is now 100% perfect :D
You will be able to see if the external power connector is ok on your unit when you take the back off, if you can move the back of the external power connector on the main board from side to side slightly check the joints, if you dont this will only get worse and probably break the connector off the board with devastating results 8O
I could only really solder one side of the back of the external connector as my iron is too large but I am going to get a smaller one to do the other side just in case.
Heed my advice if you have problems, it is only four screws to open it up Remove any SD card and carefully take the black plate off the back starting from the antenna end unclicking it a you go towards the volume end.
On refitting the back make sure you fit the volume control end in first then slowly click the back on and rescrew it up.
Make sure you have it turned off and do not press on the screen whilst doing anywork on it.
If you want to disconnect the battery that would be a good idea but dont forget to back it up before so you can restore it, I did it with it still in place but I always wanted to play with the devil! Twisted Evil
Please also note DO NOT solder it whilst it is on or you might be crying at the end of it! Crying or Very sad
Be careful anyway and remember you are doing this at your own risk not mine!
tel33
IPAQ 3950 Tomtom 6 with Navman 3450 sleeve v6 USA & Canada & Western Europe maps, 2gb Sandisk sd card, POIWarner V2.0.
TomTom 920T, v715 maps for USA & Canada, Western & Central Europe, 4gb SDHC Transcend Class 6
22.062 (12 Jun 24)
