Rogerland Occasional Visitor
Posted: Sat Sep 03, 2005 10:07 pm Post subject: |
This might sound daft but how do you install this program on your pc. I have XP and have microsoft.net 1.1. When I click on the 'offlinetraficnewssetup.msi' it just open up another folder with 7 files in it. The file names are made up of a mixture of numbers and letters.
Hope you can help |
Posted: Sat Sep 03, 2005 10:21 pm Post subject: |
Ignore my last post above. Just realised what i was doing wrong. |
Darren Frequent Visitor
Posted: Sat Sep 03, 2005 10:58 pm Post subject: |
Latest version now uploaded, download via link in opening post to this thread. _________________ Darren Griffin |
oka97 Occasional Visitor
Posted: Sun Sep 04, 2005 12:49 am Post subject: |
Thanks for that.. Now in the destination directory I get a squillion log files, each different but containing something similar to:
http://www.bbc.co.uk/travelnews/tpeg/en/local/rtm/coventry_tpeg.xml
The underlying connection was closed: Unable to connect to the remote server.
The thing is if I can access that URL from Internet Explorer!
I also get these appearing in my event logs but I think they're unrelated
DCOM got error "The service cannot be started, either because it is disabled or because it has no enabled devices associated with it. " attempting to start the service IISADMIN with arguments "" in order to run the server:
{A9E69610-B80D-11D0-B9B9-00A0C922E750}
Oh well, I was getting excited about this little tool :-)
Good luck anyway, take care! |
Posted: Sun Sep 04, 2005 1:14 am Post subject: |
Eep, I posted too soon!!
Fixed the problem, app worked like a dream.
It was a screw up with my PC, nothing wrong with the software itself.
Excellent tool, well done keep up the excellent work :-))))))
The only hint I can think of now is to show a download meter so the users are in the know. |
hogbreath Regular Visitor
Joined: Feb 07, 2004 Posts: 139 Location: Hillingdon, Middx
Posted: Sun Sep 04, 2005 4:15 am Post subject: |
New OTN version loaded, now get a load of OTN text files (81 in total) with for example this text inside one of the files:-
http://www.bbc.co.uk/travelnews/tpeg/en/local/rtm/bedfordshire_tpeg.xml
The remote server returned an error: (404) Not Found.
Looking in a few more of the txt files, I see they are all the different counties.
Got a ov2 file but with 0kb file size.....
Did notice the box you have allowed in "Options" for proxy settings. Went & entered "http://www.ukonline.net" but no luck so far.
Pete |
rsutcliffe Occasional Visitor
Posted: Sun Sep 04, 2005 10:00 am Post subject: |
If you are running through a proxy server the url in options should be entered like so:
http://123.234.123.120:321
If you don't use a proxy then you shouldn't enter anything into this field.
The logging is in place to assist me in finding the cause of issues. Once you are up and running you shouldn't see anymore of these appearing. |
Posted: Sun Sep 04, 2005 11:49 am Post subject: |
Guys, the problem I had was, I use Firefox and its own proxy settings on my PC are nothing, but IE has its own proxy config too and the big difference is the proxy settings for IE are global to the entire OS! I found I indeed had a proxy set on my IE so I removed it and OTN worked!
If you're at home you really don't need a proxy, so remove it out of IE and leave the proxy field blank in OTN.
I had the same problem as you hogbreath and this fixed it. |
SandyMac Occasional Visitor
Posted: Sun Sep 04, 2005 12:08 pm Post subject: OTN Problems |
Not sure what I'm doing wrong but successfully installed OTN and it automatically updates exactly as it says on the tin but can't see the overlay when I run TT5. I do see it in the map folder so know its there. How do I set it up and use this fantastic utility?
Posted: Sun Sep 04, 2005 12:28 pm Post subject: |
oka97
Where is the proxy setting in IE & yes I'm using Firefox. Assume you have to put IE back as the default window.
Another annoying glitch is I now get a Logon Window requesting a password, have not entered one, but still it shows, assume this came courtesy of .NET Framework
Thanks in advance to all
Pete |
UsuallyLost Pocket GPS Verifier
Joined: Jul 20, 2004 Posts: 81 Location: Warwickshire, UK
Posted: Sun Sep 04, 2005 2:37 pm Post subject: Impressed! |
Very impressed Richard.
Loaded .net 1.1 from the Windows Update site, Then loaded OTN.
I set the download directory to my Great Britain map dir on my iPaq, and the secondary one to where I keep all my POIs on my PC, and everything works first time. The only thing I had to do was to tell my firewall to allow OTN through!
I'm just a little worried that I may have overload of info as I have already got all my cameras popping up audio warnings!
FYI - using the following.
Win98SE with ActiveSync 3.7.1
Old iPaq with TT3 and Checkpoint 3.2
NAT router (hardware) and ZoneAlarm firewall on the PC
Thanks again,
Noel :D :D :D _________________ iPhone 5 with TomTom Western Europe and Australia.
iPad mini with TomTom Western Europe |
Posted: Sun Sep 04, 2005 3:44 pm Post subject: |
If you're at home you really don't need a proxy, so remove it out of IE and leave the proxy field blank in OTN. |
Went & unchecked the http settings for 1.1 (both boxes) - but still no luck
What now
Pete
ps. would prefer OTN as an icon on the desktop not collecting updates automatically enabled system tray |
Posted: Sun Sep 04, 2005 4:33 pm Post subject: |
in IE go to the drop down:
TOOLS
then [Internet Options]
then [Connections] tab
then [Lan Settings]
uncheck 'use proxy server'
Hog, run netstat ([netstat 3]) from a command line and see if OTN is even sending out any traffic on your network connection. |
Posted: Sun Sep 04, 2005 4:37 pm Post subject: |
If someone could just have this churning out data to a public web location, that'd be fantastic!
Mr. Sutcliffe you need to speak to PocketGPSWorld and ask them to host a file you can update via FTP or something, every 30 mins or less.
This would be better than an application running on every PC, and it would add value to the PocketGPSWorld site up there with the speed camera db, surely that would be in their interest. |
