westentertainer Frequent Visitor
Posted: Fri Sep 02, 2005 6:49 pm Post subject: bt reciver to ipaq 5450 |
i have just purchased a ipaq 5450 and want to bond with bt receiver i have paired both devices ,when i go into tomtom it saks me what device i choose other gps bluetooth it saks me to bond ,then a list of conections eg.. com 1 com usb..etc what one do i choose many thanks |
stevei Lifetime Member
Posted: Fri Sep 02, 2005 7:29 pm Post subject: |
Should be COM 8 _________________ Steve I |
Posted: Sat Sep 03, 2005 6:14 pm Post subject: |
there is no com 8 in list !!!! |
Posted: Sat Sep 03, 2005 7:09 pm Post subject: |
Do any of the options start Bluetooth Serial Port....?
I have two such options on my iPAQ5555, one for CommPort 5 and one for Commport 8. I use CommPort 8 which is first on the list. If you have any such Bluetooth Serial Port options, just try them after pairing. _________________ Tim |
Terminator Occasional Visitor
Joined: Mar 25, 2004 Posts: 20 Location: Derby, England
Posted: Sat Sep 03, 2005 9:16 pm Post subject: |
I've got the 5450 and it uses COM8 to connect to my BT receiver.
TT5 lists these connection options when I select "Other Bluetooth GPS" :-
Serial Cable on COM0
COM3
Serial Cable on COM6
Native IR
USB Cable
Serial Cable on COM1
Bluetooth Serial Port COM8
Bluetooth Serial Port COM5
Although on screen the it shows "Bluetooth Serial Port..." as the font is huge |
Posted: Sun Sep 04, 2005 3:31 pm Post subject: |
th bt reciver works ok with spv200e do i need to download drivers to ipaq to get it to work?
perhaps its a pairing problem as when i select other bluetooth device it asks me to bond with phone yet the ipaq states ti is bonded although there is a question mark over bonded device in menu |
alix776 Pocket GPS Moderator
Posted: Sun Sep 04, 2005 3:39 pm Post subject: |
add it as a paired device on the ipaq should work after that are 5.00 or 5.01 use the update as there a problem with tt5 in the orignal release with other bt gps try other wired and set the baud rate and com8 and se if that works _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
