Pocket GPS World :: View topic - medion gps receiver not working
absolutecooling
PostPosted: Thu Sep 01, 2005 11:50 am    Post subject: medion gps receiver not working Reply with quote
i have a medion pocket pc which had medion sat nav on and worked fine , updated to tom tom version 5 as the maps are more up to date and now when i run the sat nav i get every thing but a signal from the receiver. gone into settings and clicked on other cable gps and set baud rate to 4800 but still no gps device seen. can any one help thanks jay.
Sequin
PostPosted: Thu Sep 01, 2005 12:25 pm    Post subject: Reply with quote
When setting up the receiver, set it to Other Cable NMEA, Baud 4800, Serial Cable on SP2
jono400
PostPosted: Wed Oct 12, 2005 12:50 am    Post subject: Reply with quote
Hi, just wonder how you got on with the suggested settings for your medion pda / gps receiver, using the combined medion ppc150 pda / gps rx myself and having installed tt5 tnight looking to set the gps receiver up correctly.
cheers,
john
jono400
PostPosted: Wed Oct 12, 2005 9:19 am    Post subject: RE. Reply with quote
Right guys further to my last post, have entered the suggested settings into my medion ppc150, just one thing during this set up process it will give you the option " specify your gps hardware, si I press " other cable NMEA GPS " then select then GPS baud rate so I choose 4800 then I press " done " so it will then show the " GPS is connected to :
usb cable
serial cable on SP2
serial cable on com1: com 3
native IR:
there is a cancel button at the bottom off the screen and his will take me back to the " specify your gps hardware " screen as before so I take it the info that I previously set is already saved on the PDA ??
slighty confused in this final part off the set up process !!! and would appreciate if anyone could help me out, would certainly be appreciatted.
cheers, Smile
john
Pocketgps
PostPosted: Wed Oct 12, 2005 1:10 pm    Post subject: Reply with quote
You need to select 'serial cable on SP2' on that screen, then it should take you back to the configure screen, the sats may take several mins to start showing as grey bars first, then after another few mins they should start turning to blue bars, at this stage on that screen top left it will then show 'other cable NMEA GPS', but only as you get the blue bars that show a lock.
Pocketgps
PostPosted: Wed Oct 12, 2005 1:46 pm    Post subject: Reply with quote
If you cannot get it to show a lock on the sats (blue Bars), then I have a gps firmware update for the Medion MD95000 - Model No. MDPPC150,
but only for that version.
You can download it Here
There is also a video of the settings Here,
it's a 1.05MB download
jono400
PostPosted: Wed Oct 12, 2005 10:38 pm    Post subject: Reply with quote
Thanks so much for your helpful replies folks, all up and running now.
cheers,
john
22.064 (26 Jun 24)
