Pocket GPS World :: View topic - ActiveSync - downgrade...........HOW?
Martin46
PostPosted: Mon Aug 29, 2005 7:58 pm    Post subject: ActiveSync - downgrade...........HOW? Reply with quote
Confused HELP I'm running out of time before a lengthy journey. Ihave followed the How to install (camera database)POIs to Tom Tom Naigator 5 guide ,downloaded the database - also PoiEdit done everything in the correct order and reach the point of the Update Status window that stops loading on the pocketgps-contenental.................then "Could not create remote file.................. " I then read the guide instruction about downgrading ActiveSync to v 3.7 or below (I'm running v3.7.1 and can only assume that this is the problem ) .How do I downgrade ActiveSync? Any advice would be great Exclamation toPOInt me in the right direction
xda
PostPosted: Mon Aug 29, 2005 10:02 pm    Post subject: Reply with quote
I'm using 3.8.0 build 5004 available from the Microsoft site. No problems with it on Windows XP Pro.
Graham.
Map: Europe V910.4892
Nokia 925 Windows 8
Talkingbollox
PostPosted: Mon Aug 29, 2005 10:40 pm    Post subject: Reply with quote
if you're stuck you can just cut and paste the .ov and .bmp files to your map folder, assuming it's on flash media and you've got a card reader.
Martin46
PostPosted: Wed Aug 31, 2005 11:53 pm    Post subject: Everything now working !!! Reply with quote
Clap Thanks guys I had lost a bit of faith after my 1st Tom Tom failed and was a bit wary of how to get going without a bit of back up Jumping With Joy followed your advice and tried it out this morning all okay.
pnb
PostPosted: Thu Sep 01, 2005 10:12 pm    Post subject: Reply with quote
I have the same AS with XP Pro and it also failed to Sync the poi files.
I also assumed that it was the version stopping it.
I do not really want to downgrade AS so any suggestions would be welcome.
Peter
drrbr1
PostPosted: Sat Sep 03, 2005 9:42 pm    Post subject: Active Sync Version Reply with quote
I too had "upgraded" to 3.8 with subsequent sync/download problems. At the time - some weeks ago, I simply went to the Microsoft website and downloaded and re-installed 3.7. During installation I was asked whether I wanted to overwrite a newer version with an older version but otherwise no problem. I cannot remember the details now but 3.8 seemed to offer little over 3.7 hence it was a simple decision to 'downgrade'. Is " Horses for Courses" appropriate? In my case POISync took priority.
22.062 (12 Jun 24)
