buphone Occasional Visitor
Posted: Fri Aug 26, 2005 10:17 pm Post subject: Marking gps position off road |
tomtom allows you to mark a gps position. Unfortunately, if it is off road, it says 'No usable locations near GPS position'. I was surprised that I can't use it to help find my car.
Has anybody managed to do this? |
erniew Lifetime Member
Posted: Sat Aug 27, 2005 6:19 pm Post subject: |
i work in a spot where the m1 is 50 meters one way and a minor road is 50 meters the other when i park in the carpark and try to set the gps point it will either set to the m1 or if i am nearer to the minor road it will set the gps point to that
it will not set to a point that is not on a road i presume because it needs roads to navigate you to the set point
i may be wrong but thats my view
i navigate to the trams in notting ham and the nearest i can get is wilkinson street it allows me to set a point on that road but will not set a point in the carpark that is not mapped
when you start from a point that is not on a road tt is lost until you get to a road so that it knows where you are
hope this helps
erniew |
kartracer Frequent Visitor
Joined: 26/03/2003 20:15:33 Posts: 502 Location: United Kingdom
Posted: Sat Aug 27, 2005 6:44 pm Post subject: |
TomTom will not navigate to a position which is off-road. You can mark one, but it will just take you to the nearest point it can reach by roads it knows about. _________________ Kam |
Posted: Sat Aug 27, 2005 10:52 pm Post subject: |
Thanks for the replies.
The inability to calculate a route is something that I can tolerate. However, the ability to identify the position would be useful.
I think I may have a workaround.
1. Use 'Browse map' and put the cursor on top of the GPS position.
2. Save the cursor position as a favourite. It will be shown on 'Browse map' as a star.
3. To get yourself back to that position, simply head towards the star.
Does that work for you guys? |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10644 Location: Suffolk, UK
Posted: Sat Aug 27, 2005 11:02 pm Post subject: |
It works on the TTG, so should be the same for you. _________________ Richard
TT Via 135 App 12.075: Europe Map v1145 |
Posted: Sun Aug 28, 2005 10:11 am Post subject: |
buphone wrote: | Does that work for you guys? |
Yes. Using it as a compass to assist you as navigator, rather than using it as the navigator will work off road. _________________ Kam |
dhevans_6 Regular Visitor
CJackel492 Regular Visitor
Posted: Wed Aug 31, 2005 9:41 am Post subject: |
If you have a s60, s80, s90 or UIQ you could try Mapview from WIld Mobile,
http://www.wild-mobile.com/
This is a basic GPS tracker program that you can program in a GPS point and it will give you heading, distance, ETA, ect...
It will also track you as you move around,
You can also load your own maps into it,
Carl, _________________ Phones - Nokia 9500 + a few others
Nokia 9500 running TTM5  |
sm1thson Occasional Visitor
Posted: Wed Aug 31, 2005 6:42 pm Post subject: |
its a pain the other way round, when you are in a carpark and trying to set a route! it wont calculate it untill you are on (/near) the road. it could just calculate the route and tell you to find your own way to the road to start off with. |
Posted: Wed Aug 31, 2005 7:18 pm Post subject: |
i normaly find it will calculate a route from a car park but it has to have an active gps satelite connection
it then goes awray until it finds a road it can start from
i have not tried this from a multi storey but it works on a flat car park
erniew |
