I have XP home and as the only user, the machine boots straight to the desktop, which is just the way I want.
However, when I install .Net Framework with no alterations to configurations, XP boots to the log on screen.
Is it possible to set the machine with .Net installed, to boot to desktop?
(I know his is the wrong place to ask but after an hour trying to search MSKB (!!!!) I decided to risk the wrath of you lot and hope some kind guru will assist. Please...
Thanks _________________ Axim X50 & TT5, Arkon CM820 powered mount with built in sirf2 gps
Axim 5 sans GPS Rx
Ford Focus 2L Ghia, Wife, kids, dog, cats, mortgage, bank manager & taxman to support, debts, windows need painting - (I cut the grass! - its rained - it needs
Posted: Tue Aug 30, 2005 12:23 pm Post subject: Re: OT: .net or xp guru + gps help needed please
alanparrott wrote:
Donald wrote:
...Is it possible to set the machine with .Net installed, to boot to desktop?
Yes that'll be fine. Just remove the settings. The only time you must have a log on is if you are using IIS.
Alan
Thanks Alan. What settings do I need to remove?
I don't think i have a need for IIS...
I would like to run one or two proggies that need .net.
Because of the multitude of monitoring progs running in the background (Zone alarm, Giant, Spysweeper, Norton AV, wlan, wireless mouse/keyboard et al) it take a little while to settle down and bed in. Therefore, when I switch on, I go for a pee or make a coffee whilst it does its thing... Having to wait for the bloody logon screen before I ablute, when I'm the only user is a pain in the rear!
Your guidance will be appreciated
Donald _________________ Axim X50 & TT5, Arkon CM820 powered mount with built in sirf2 gps
Axim 5 sans GPS Rx
Posted: Tue Aug 30, 2005 12:26 pm Post subject: Re: OT: .net or xp guru + gps help needed please
Alan
I forgot to add that I have uninstalled .Net framework so I cannot check but I take it that I should (karefully) mess about with control panel\admin or user settings once .net is back on board? _________________ Axim X50 & TT5, Arkon CM820 powered mount with built in sirf2 gps
Axim 5 sans GPS Rx
there should be a setting there to change the way you Log on, I have a few machines and they differ on some.
Alan
Thanks Alan - All I could find was the option to use XP or Classic method of Logging on.
maybe I should re install .Net and see if I can fix it - If not, I'll just have to uninstall it again...
Thanks for your guidance Alan
Regards _________________ Axim X50 & TT5, Arkon CM820 powered mount with built in sirf2 gps
Axim 5 sans GPS Rx
Posted: Tue Aug 30, 2005 2:20 pm Post subject:
On a side note GPSdash doesn't reqire the .Net Framework but the .Net Compact Framework (CF) on the PDA. all WM2003+ machines have that in ROM _________________ Lutz
Thanks for that. I will d/l it now .... & give it a spin.... _________________ Axim X50 & TT5, Arkon CM820 powered mount with built in sirf2 gps
Axim 5 sans GPS Rx
