DreX Occasional Visitor
Posted: Fri Aug 26, 2005 7:30 pm Post subject: |
I have tried this on a medion unit (pna150)
and it works flawlessly
AS for Warranty
The unit itself is just a pocket pc running windows ce
its like saying you pc warranty will be invalid
if you run anything other than the pre-installed
programs
All Traces of any other programs will be lost
when you do a hard reset
e.g. Switch off master switch on back of unit. |
ShirleyTemple Regular Visitor
![](modules/Forums/images/avatars/39660440245fe9ac1e9aa4.jpg)
Joined: Feb 11, 2005 Posts: 141 Location: Southampton/Portsmouth
Posted: Fri Aug 26, 2005 7:36 pm Post subject: |
All is needed is for someone to give us less confident types a blow by blow account of how to do it.
Come on guys, help us out, please. _________________ Navman iCN 520 |
Tim Buxton Pocket GPS Moderator
![](modules/Forums/images/avatars/483587116439494e7a5e13.jpg)
Joined: 14/09/2002 20:56:18 Posts: 5231 Location: Surrey, United Kingdom
Posted: Fri Aug 26, 2005 7:42 pm Post subject: |
DreX wrote: | I have tried this on a medion unit (pna150)
AS for Warranty
programs
If it works for you and you're happy to take the risk, that's fine. As to the warranty, it's nothing like saying what you suggest. It would be more like unlocking your Vodafone branded mobile to be able to use any SIM card; if you did such a thing and the 'phone went wrong, Vodafone wouldn't be obliged to mend it.
But as long as you're sure that all traces are lost after a hard reset, you've nothing to worry about. Personally, I'd wait until the warranty had expired. _________________ Tim |
Paulius55 Occasional Visitor
Joined: Jun 07, 2005 Posts: 17 Location: Rushden, Northants
Posted: Fri Aug 26, 2005 10:26 pm Post subject: |
Pau1C wrote: | Paulius55 or Humpadilly,
Could either please give us a blow by blow account of how you did it in English Please and what happens when you switch unit on and off.
The Old brain cells are a bit slow.... Sorry
Thanx in advance |
All I did was follow the instructions that came with the original post. One key point is that you copy files from PC explorer to Navman by using the Explore option in AtiveSync. Just drag files from one to another. You have to do this as the PC explorer cannot explore the Navman. If you switch the unit off with the normal on/off switch on the front it comes back to whatever you were doing last, as that is a type of low power standby. If you switch the battery off, or press the reset button, it goes to the new menu, with Navman, MP3 player, Calculator, Explorer etc. Navman is totally unaffected, but to get to WinCE when in Navman you have to press the reset button. |
Posted: Fri Aug 26, 2005 11:04 pm Post subject: |
OK. I'm up and running with this now. A couple of questions though, until I think of more.
I'm not familiar with PDA's, so how do I load mp3 and jpeg files onto the 510 now.
The calculator doesn't fit the screen properly which means the "Exit" "X" is out of view.
It's looking good though. _________________ Navman iCN 520 |
Posted: Fri Aug 26, 2005 11:43 pm Post subject: |
OK...........I've cracked the MP3 Player that's no sweat but I'm struggling to get JPEG images to fit the screen and not all applications seem to fit the screen 100% either.
I'll let you know how I get on. _________________ Navman iCN 520 |
Paul80 Regular Visitor
Posted: Sat Aug 27, 2005 12:31 am Post subject: |
Hi all
Does anyone knoe if this will work with the new iCN520.
Thanks |
ipaqy Occasional Visitor
Joined: Jun 18, 2005 Posts: 7 Location: Omaha, NE. USA
Posted: Sat Aug 27, 2005 4:07 am Post subject: |
I've got it intalled on my 510 as well and it's working alright except Explorer in the main menu--is this function working for you guys? Anyone try loading TomTom 5 yet? How does one go about installing other programs, will they automatically show up in the main menu or does something need to be done to get them there? |
Posted: Sat Aug 27, 2005 8:50 am Post subject: |
ShirleyTemple wrote: | OK...........I've cracked the MP3 Player that's no sweat but I'm struggling to get JPEG images to fit the screen and not all applications seem to fit the screen 100% either.
I'll let you know how I get on. |
Could that be because the iCN is a landscape device and the apps are designed for portrait? You should be able to rotate your images through 90º; don't know how you might rotate apps, though. _________________ Tim |
Posted: Sat Aug 27, 2005 10:32 am Post subject: |
Just tested this on my 520 and it does install ok.
Anyone know how to add the installed apps to the front menu and also If I install TomTom which version do I use, I tried version 5, which reporded it installed ok but I cannot find the app on the 520 to use it.
Paul |
Posted: Sat Aug 27, 2005 11:27 am Post subject: |
Tim said.......... Quote: | Could that be because the iCN is a landscape device and the apps are designed for portrait? You should be able to rotate your images through 90º; don't know how you might rotate apps, though. |
I'm only getting about a tenth of the image Tim so I think it must be something to do with the resolution of the image that's imported. I can't find a + or - magnifier option in the MS Paint or MS Image application.
It's a pity all my music on my HD has been ripped using Win. Media Player as it's all in WMA and not MP3. Guess I've got some converting to do.
ipaqy...... can't see anything wrong with my Explorer, what is the exact problem? _________________ Navman iCN 520 |
mrg2003 Regular Visitor
Joined: 12/03/2003 18:19:15 Posts: 136 Location: United Kingdom
Posted: Sat Aug 27, 2005 12:05 pm Post subject: Installing Jandrics menu + tt5 on navman 510 |
My experience
Disclaimer: if you breaks yer 510 don't blame me or Aleks.
Do's and don'ts.
Do Send Aleks $5 or more for this excellent program.
Don't ask me about unlicenced versions of tomtom !
!!! DON'T MESS WITH THE FLASH !!!!
I got a spare 510 and used that.
Download and extract the zip
http://www.eurocom-ad.nl/eurocom/navman.zip
follow his instructions. I made my own self extracting file to downlaod everything to the correct place.
I may post it, if I get permission from Alex as it is effectively re-packaging his work, and I'd like permission.
Problems I found
Running the registry tool, the program crashes. Resstart the navman device. You want the connect mobile device registry option.
Reconnetc usb cable.
Try running registry tools again, it worked after a few attempts.
Installing tomtom.
To install tt5 and have navman you need a 256M card. You will need a new PPC id. Tomtom were very helpful when I said I wanted to install on a navman.
The installer crashes a few times.
eventually I got a clean install. Persist
Problems
obviously the navman buttons won't work (but someone is working on a keymap). Some of the tomtom screens don't fit properly. It locks up frequently, but then my XDA+tomtom locks up all the time too.
Things not to do !!!!!
(unless you know about JTAG:) Don't muck with the navman flash, like putting this menu to download from there, it breaks the checksum and you will have a brick and need recouse to JTAG.
Future work - This will problaby progress no further as +
User configurable menu
restore from SD card
Mr.G - GPS addict
GPS's
Mobile
XDA2+Fortuna+TT5
IPAQ3870+navman GPS back
TT Go 500
Navman ICN510
Fixed
Trimble
Siemens
Pocket
Garmin Vista
+I will have found some other toy to play with $$![Sad](modules/Forums/images/smiles/icon_sad.gif) |
xnappo Occasional Visitor
Posted: Sat Aug 27, 2005 3:07 pm Post subject: |
Cool, now I can use my NavMan for Geocaching! Anyone have suggestions on the best GPS SW for Geocaching?
xnappo |
Posted: Sat Aug 27, 2005 8:42 pm Post subject: |
It's looking good though. |
This is easy to fix. In the calculator look at the view menu, and there you can change the size of the on-screen buttons, number of columns, size of the fonts, colours etc. |
Posted: Sat Aug 27, 2005 9:13 pm Post subject: |
Paulius55........Yes I sust that one out thanks. But I'm still struggling with MS Paint. I'm not getting access to all the tools in the top Tool Bar. Is it possible to play more than one MP3 file? I only seem to be able to play one file track at a time?
I still can't get any JPEG files to display more than about a tenth of the picture at the moment. It wouldn't be much use as a picture viewer as I think the processor is too slow for that job which is what I would have liked to use it as. _________________ Navman iCN 520 |
