jeff261159 Occasional Visitor
Joined: Aug 08, 2005 Posts: 30 Location: Portsmouth, Hamphire
Posted: Thu Aug 25, 2005 8:19 pm Post subject: PDF reader for pda's |
is there a pdf reader programme for pda's? |
Posted: Thu Aug 25, 2005 8:29 pm Post subject: |
Sure, Adobe Reader V2 for PPC, which you can download from here. _________________ Tim |
Posted: Thu Aug 25, 2005 9:25 pm Post subject: pocket pc adobe acrobat |
i tried that, after downloading it says its not a valid pocket pc application! |
xda Lifetime Member
Posted: Fri Aug 26, 2005 2:47 am Post subject: |
Which version did you download? there are 2 versions.
Pocket PC Version 2 for Pocket PC 2002 and Windows Mobile 2003. File size = 13.5 MB.
Pocket PC 2002 for Arm X-Scale. File size 8.4 MB.
The one I installed and use is the Arm X-Scale version. _________________ Graham.
Map: Europe V910.4892
Nokia 925 Windows 8 |
lbendlin Pocket GPS Staff
Posted: Fri Aug 26, 2005 4:36 am Post subject: |
My iPAQ 6315 has a built-in Clearvue PDF reader... _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
xda Lifetime Member
Posted: Fri Aug 26, 2005 4:53 am Post subject: |
lbendlin wrote: | My iPAQ 6315 has a built-in Clearvue PDF reader... |
So has my XDA II, but I find that Clearvue when it loads a .pdf file, you have to scroll across to read all the text, were as Abode displays the text without having to scroll across the screen. _________________ Graham.
Posted: Fri Aug 26, 2005 11:40 am Post subject: pda adobe |
i tried both versions but they both id not a valid pocket pc application. do need to download from the pda or via the pc and then install with t
e pda in the dock? |
kartracer Frequent Visitor
Joined: 26/03/2003 20:15:33 Posts: 502 Location: United Kingdom
Posted: Fri Aug 26, 2005 3:42 pm Post subject: Re: pda adobe |
jeff261159 wrote: | do need to download from the pda or via the pc and then install with t
Execute the downloaded file on the PC with the PDA connected via Activesync. That should then install the reader onto your PDA. _________________ Kam |
Posted: Fri Aug 26, 2005 4:24 pm Post subject: pda adobe |
that did it! thanks for all the help |
