Pocket GPS World :: View topic - Problem installing Speed Camera POIs
MJC
PostPosted: Thu Aug 25, 2005 12:10 pm    Post subject: Problem installing Speed Camera POIs Reply with quote
I have a problem installing the speed camera POIs in that they don't seem to want to co-exist with each other. eg. when I copy all the gatso zone files, they show up ok, eg. gatso_20, gatso_30... etc. But when I then add all the mobile_30, mobile_40... etc files - some or all of the gatso files no longer show up in the POI list. And vice-versa.
Has anyone else experienced similar symptoms, or have any idea of what's happening?
Thanks.
Privateer
PostPosted: Thu Aug 25, 2005 12:21 pm    Post subject: Reply with quote
Hi MJC,
How many POIs have you got loaded on your GO? If you're running version 5.201 then the maximum number of POI categories is 27.
For further information, there are some guides that should be read (in the following order):
Arrow The beginner’s guide to the PocketGPSWorld camera database.
This explains about the different camera types and about categories and subcategories, so that you can decide how you want the database on your unit.
Depending on whether you have TomTom Navigator on a Pocket PC or TomTom GO, please read either:
Arrow How to install (camera database) POIs to TomTom Navigator 5.
This guide explains how to load the PocketGPSWorld camera database onto a Pocket PC running TomTom Navigator 5.
Arrow How to install (camera database) POIs onto a TomTom GO.
This guide explains how to load the PocketGPSWorld camera database onto your TomTom GO.
The above guides may look lengthy and complicated when first seen. However if you grab a cup of coffee and read each one thoroughly then they should make sense as they have been written in a step-by-step way, for ease of reading.
Robert.
Garmin Camper 770 LMT-D
MJC
PostPosted: Thu Aug 25, 2005 12:31 pm    Post subject: Reply with quote
Thanks Robert.
I do have a lot of POIs installed on the card, and I did wonder whether this was the problem. However, as I understand it, I should still be able to see all the POIs I have on the card displayed in the POI list, even if I am not able to 'enable' them all... is this correct? What I am experiencing is that the camera POIs are not showing up at all in the POI list.
Oldboy
PostPosted: Thu Aug 25, 2005 5:35 pm    Post subject: Reply with quote
MJC wrote:
Thanks Robert.
You will be able to see them when you Explorer with the PC.
Unfortunately there is a limit on how many TT is able to see/handle. It will be either 27 or 40 according to which version of TT5 you have.
22.063 (19 Jun 24)
