slast Occasional Visitor
Posted: Wed Aug 24, 2005 11:03 pm Post subject: Help - dead TomTom |
Working fine a couple of days ago, just tried to turn it on prior to departing for France at 0330, - nothing happens! No power light on with either computer feed or car adapter.... any ideas??
Steve |
sgould Frequent Visitor
![](modules/Forums/images/avatars/12745715643c17d95b9699.jpg)
Posted: Wed Aug 24, 2005 11:15 pm Post subject: |
Green power light should come on if you have power.
Sometimes it can discharge when you think it's switched off, especially if you let it switch off with the ignition.
What colour fuse is in the charger lead? If it's purple, try and check the output voltage - this is the early model and sometimes fails and gives a fatal 12v to the Go instead of 5v.
If you have a white /clear fuse, just check the fuse. These chargers seem to be OK. But again see if you have any voltage at all at the output.
The charger is the only source of power. There is no power supplied to the GO via the USB computer lead. _________________ TTGO 700 (dead)
iPhone 3GS + TT holder
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
Kenwood DNX-4210DAB with Garmin maps |
Old_Phil Regular Visitor
![](modules/Forums/images/avatars/gallery/starwars7.jpg)
Posted: Wed Aug 24, 2005 11:16 pm Post subject: |
Check output of car adaptor - if it's 12v then you have fried your GO.
If 5v, then perhaps on/off switch has jammed. Try removing the fascia and re-fitting. My GO classic did this once and has been fine since. In fact, check that out first - it's an easy fix.
Otherwise, sounds terminal.... _________________ GO 700 App 6.520 WE Map v568.0
"If anyone tells you that retirement is harder work than working, listen to them - they ain't kidding!!" |
Posted: Wed Aug 24, 2005 11:39 pm Post subject: |
thanks guys, will try those ideas - power should be correct voltage as it's the TomTom original charger and worked fine previously.
Steve |
Posted: Wed Aug 24, 2005 11:48 pm Post subject: |
OK. seems like it is a poor connection in the adaptor, the green light on that is intermittent but it does produce 5V when ITs light is on, and then we are back in business so it looks like it was a flat internal battery.
Thanks for the advice, saved me a lot of cursing and getting lost tomorrow!!
Regards
Steve |
