Pocket GPS World :: View topic - tom Tom Go 500 - set up problem
Braveheart252
PostPosted: Wed Aug 24, 2005 10:02 pm    Post subject: tom Tom Go 500 - set up problem Reply with quote
I set up my Go 500 hardwired in my car and it works fine. Somewhere I have set it to only go to night screen when my headlights are on. This doesnt work so bright day screen at night. How do I remove this option so I can switch manually?
TuurG
PostPosted: Wed Aug 24, 2005 10:06 pm    Post subject: Reply with quote
in Docking preferences, i believe that menu option is in screen 5 or 6 of the preferences menu.
rkm_hm
PostPosted: Wed Aug 24, 2005 10:12 pm    Post subject: Reply with quote
Change preferences / Docking preferences / Link night view to headlights
HTH.
Roger
TomTom via135
Satmap Active 10+ v1.50 with full UK 1:50k map and 1:25k/1:10k County maps of Hampshire & Warwickshire
Braveheart252
PostPosted: Wed Aug 24, 2005 10:37 pm    Post subject: Reply with quote
Excellent...soved many thanks!!!!!!!
rkm_hm
PostPosted: Wed Aug 24, 2005 10:52 pm    Post subject: Reply with quote
Good.
When you refer to 'hardwired' are you using the optional (and expensive!) car installation kit? If so, if this is correctly installed it should have connections to the headlights (for the purpose you mention) and to the radio (for muting).
If you're just using the standard mount - but hardwiring the power rather than using the cigar lighter socket - it doesn't do any of these things.
Roger
TomTom via135
TuurG
PostPosted: Thu Aug 25, 2005 9:43 pm    Post subject: Reply with quote
rkm_hm wrote:
Good.
The connection to the headlights goes via the ISO connectors. If the wiring loom of your car does not have the headlights connected to the ISO connector, then it will not work.
22.064 (26 Jun 24)
