icsys Frequent Visitor
Joined: Feb 20, 2004 Posts: 1154 Location: South Lancashire, UK
Posted: Sun May 22, 2005 11:02 pm Post subject: |
I stand corrected. (I should have checked first)
It seems the format has changed.
The 'pocketgps_uk_sc' file is new and now contains the GATSO, mobile, truvelo, redlight, specs and temporary camera locations in one file.
Sorry. _________________ Ian.
iPAQ 2210 | Navman 4100 BT Receiver
Navman iCN 635
TomTom GO
Anquet OS mapping
ToonNo9 Occasional Visitor
Posted: Tue Jun 07, 2005 1:15 pm Post subject: Individual sound warnings for various POI's |
104456 wrote: | To the latter question yes you should just update the csv file and it will use the same bitmap.
On a side note I notice if you look at the ini files relating to these POIs there is a default sound set so this would suggest putting the relavent sound file within the windows folder and ammending the last line of the ini file would produce individual sounds for each type of camera encountered. |
Has anyone tried this out yet ?
If not, does anyone know the path to the ini files on the Navman. I might give it a whirl. _________________ HTC Desire HD & CamerAlert
welsey Occasional Visitor
Posted: Wed Jun 08, 2005 9:51 pm Post subject: speed cam icons |
hello everyone, it says in the instructions, add the icons for the speed cams. i have added the bmp files like you do to install the csv file but i get an error messing doing it this way. how should i install the icons ? do i need to change it to a jpeg ?
thanks welsey |
Posted: Wed Jun 08, 2005 11:02 pm Post subject: |
welsey, can you be a bit more specific? The .bmp file should be selected using the Navman Desktop POIEditor, and bitmap is the correct format, not jpeg. _________________ Tim |
justin666 Banned
Posted: Thu Jun 23, 2005 10:18 am Post subject: help |
ive loaded all the cams eg gatso/redlight specs etc but i never saw the truvelo cams is that listed too?? also what are the pocketgps_continental.* cameras???? where will i find the truvelo camera database
i must say well done on the current database its spot on!!
regards
Justin |
Posted: Thu Jun 23, 2005 10:23 am Post subject: |
Truvelos are listed in the main Gatso databases. Continental list cameras on the Mainland, although it is a bit sparse. _________________ Tim |
justin666 Banned
Posted: Thu Jun 23, 2005 3:16 pm Post subject: |
oh right i think i better increase the range as they get you from the front the crafty things
would you say its wise to change the set ding sound to an speaking one as ive heard it can duff up the rest of the route your on i.e "warning spead camera ahead"
regards
justin |
Posted: Thu Jun 23, 2005 5:59 pm Post subject: |
I don't have a 510 to experiment with but from what I've read, I'd be inclined to leave well alone. _________________ Tim |
Nigbo Regular Visitor
Posted: Thu Aug 04, 2005 6:50 pm Post subject: 31.7.05 speed database downlod |
just downloaded this & find when I open the crv files in notepad, there is no lat / long info to delete. I have opened all crvs & saved in notepad format - but pois says 'doesn't recognise format'. Has something changed since last months download which behaved as normal? |
Posted: Thu Aug 04, 2005 6:57 pm Post subject: |
i stand corrected - done it all again & it now works - but didn't 1st time round - weird - must have opened another file?? |
simz Occasional Visitor
Posted: Wed Aug 24, 2005 9:56 pm Post subject: |
I have been asked to add the camera database to a mates Navman, I have followed ALL of the intructions and all I get is an error saying that no POI's were found in the input file. I have spent about 5 hours messing about with this and I'm at the point of paying my mate for the Navman just so I can smash the bloody thing into very very small pieces.
The whole sodding Navman thing seems like total shite to me, I am so so glad that I have a Tomtom.
Oldboy Pocket GPS Moderator
Posted: Wed Aug 24, 2005 10:32 pm Post subject: |
Two things you have to do carefully. One use the csv/other files and not the destinator files, and the other is to place a ';' in front of the header line at the top of the each .csv file, using Notepad. _________________ Richard
Posted: Thu Aug 25, 2005 3:11 pm Post subject: |
Thanks for the added info Oldboy, I decided to give it one last go before returning the Navman to it's owner.
I have followed everything to the letter (even to the point of setting the distance allert etc to the exact ones that Dave shows in his instructions) I assume the ";" is to rem the header, I tried allways with header and ";" without header and ";" the csv will load into the poi editor but all I ever get is "No POI's Found in Input File"
Many thanks for the info but it is now going to be returned. Surely Navman could have come up with a far easier way updating info in the unit?
Thanks again. |
TerryWalsh Regular Visitor
Joined: Jul 29, 2005 Posts: 147 Location: Shrewsbury, UK
Posted: Thu Aug 25, 2005 6:12 pm Post subject: |
I have a navman icn520 and following the instructions given it took about 10 minutes to load everything up. I have since created my own POI files using CSV Format it couldn't be easier. Perhaps you have a defective product. |
Posted: Thu Aug 25, 2005 8:00 pm Post subject: |
simz wrote: | the csv will load into the poi editor but all I ever get is "No POI's Found in Input File" |
It sounds very much like you are still using the Destinator CSV files.
You should be using the CSV/Other files. In Notepad you can take the header out if you like. _________________ Richard
