unders Occasional Visitor
Posted: Mon Aug 22, 2005 11:10 pm Post subject: Help Needed with connecting to tomtom services |
I have recently bought the tomtom HP 2110 navigator system.
I have followed the instructions on how to connect to services ( weather, traffic ) but i am having no luck connecting.
I have gprs activated phone and i have paired all bluetooth devices up yet i cant get anything when i am on the move.
i have signed up for 30 day free trial of tt plus and it is activated as i checked by plugging ipaq into my pc whilst connected to the internet.
But when i am mobile, it does not connect to the server.
WHAT AM I MISSING !!! i am sure it is something simple.
PLEASE HELP ME !!
THANKS
UNDERS |
Posted: Mon Aug 22, 2005 11:25 pm Post subject: |
HOW DO I CONNECT IT TO THE INTERNET WHEN MOBILE |
Rambler358 Occasional Visitor
Joined: Mar 05, 2005 Posts: 47 Location: California, USA
Posted: Mon Aug 22, 2005 11:42 pm Post subject: |
You might want to check that your cell phone has GRPS service while you're on the move. Does Navigator attempt a GPRS connection? What are the time intervals you have updates set to? |
Posted: Mon Aug 22, 2005 11:54 pm Post subject: |
hi,
It does have service on the move ( my phone )
even when i try to connect to internet on ipaq ( eg. messenger ) it says i have no modem set up.
itjust doesn't want to connect. do i need more hardware or do i need to set something up on the ipaq. pls spk to me like a beginner. |
Posted: Mon Aug 22, 2005 11:56 pm Post subject: |
it says that it is trying to retrieve but connot connect to server.
I think i need to set some sort of connection up but dont know how |
Posted: Tue Aug 23, 2005 12:26 am Post subject: |
Can you retrieve email from Messenger while you're on the move? It sounds like some kind of connection issue that's not specific to TomTom Navigator. I'd try and get that resolved first. Since I'm not familiar with your IPAQ device, I can't really help you out with that. There should be plenty of forums where you can get help with connection issues though. Once you've got that resolved, you shouldn't have any problems with TT Navigator. Good luck! |
Posted: Tue Aug 23, 2005 12:29 am Post subject: |
please help !!!
trying desperately to connect to internet via ipaq.
how!!
can i do it thru phone, if so, what do i do???
my phone is totally gprs ready |
Posted: Tue Aug 23, 2005 12:32 am Post subject: |
i see !!!
just need to know how to connect ipaq, i have no idea.
it said in instructions that i just needed gprs ready phone but there is obviously something i need to set up on ipaq.
is that correct |
brob108 Occasional Visitor
Posted: Tue Aug 23, 2005 12:36 am Post subject: |
Can you connect to the Internet via Active Sync? If you can try the TomTom services via Active Sync also. If they work then it looks like a pairing issue with your phone/IPAQ or check again with your mobile operator that GPRS is properly set up on your account.
Which operator are you with?
I had trouble with my GPRS account until I contacted O2 directly and it all got sorted. |
Posted: Tue Aug 23, 2005 1:13 am Post subject: |
Yes i can do that via active sync.
I am on vodafone and i rang them but they isaid i was gprs ready and that would do it.
still no luck
any ideas????? |
Posted: Tue Aug 23, 2005 1:37 am Post subject: |
i can do everything via activesync.
what is the best way for me to connect via my ipaq when on the move??? |
Posted: Tue Aug 23, 2005 5:02 am Post subject: |
You need to get the connection string from your phone carrier. Put that connection string into your Bluetooth manager settings. Again, I'm not familiar with your PPC device or your carrier so I can't help any more. But you should contact Vodafone and ask what connection string you should use. |
SteveW Frequent Visitor
Joined: 21/05/2003 22:54:59 Posts: 516 Location: Leicestershire UK
Posted: Wed Aug 24, 2005 1:37 pm Post subject: |
The area you need on your PDA is probably around "Start", "Settings", "Connections", "New",
Enter a Name such as "Mobile Connection"
Select a Modem "Bluetooth Dial-up Modem"
Select Baud Rate of "57600"
Select "Advanced"
Here you need the Vodafone information. The number to dial will be something like "*99#" The extra dial-string modem commands will be something like "+CGDCONT=1,"IP","VODAFONE.CO.UK"
I don't know if Vodafone uses Server assigned IP ADDRESS or not.....BTMobile does, but O2 when I used them did not.
You may be able to find more help by searching the site, I have seen this question raised before.
Hope this helps,
Steve |
Talkingbollox Frequent Visitor
Joined: 14/10/2002 15:11:34 Posts: 439 Location: United Kingdom
