dhevans_6 Regular Visitor
Posted: Mon Aug 22, 2005 10:36 am Post subject: GPS location |
We went to V in Chelmsford yesterday, all very good, apart from getting out the car park....
I thought I'd be a smarty pants and wrote down the GPS location of the car in the field when we parked. Now on the way back, it did help a little, but when we finally found the car again, the exact GPS location numbers were different! And I was standing in the exact same location!
Also I was expecting the values to update more frequently than they did, we'd walk for a bit then realise once it updated that we'd gone too far in one direction again.
I thought the new TT GPS was supposed to be sensitive to within 50cm, have I got this wrong?
Anyhow, it took me back home a different route to a lot of the cars leaving so we avoided quite a bit of traffic, so I forgave it a bit then  |
CJackel492 Regular Visitor
Posted: Mon Aug 22, 2005 3:04 pm Post subject: Re: GPS location |
dhevans_6 wrote: | We went to V in Chelmsford yesterday, all very good, apart from getting out the car park....
I think 50cm is being too optimistic,
I would have thought 10metres is more realistic,
But I've found mine can drift by 100metres or so, When stationary,
Are the American's still using SA?
Carl, _________________ Phones - Nokia 9500 + a few others
Nokia 9500 running TTM5  |
cootuk Occasional Visitor
Posted: Mon Aug 22, 2005 11:37 pm Post subject: |
Isn't there a setting on the gps receiver that makes it only update every tens of metres if in that mode (to smooth out the error in location), and another mode that continuously updates (because the SirfIII have smaller positional errors)? |
Posted: Tue Aug 23, 2005 1:09 pm Post subject: |
cootuk wrote: | Isn't there a setting on the gps receiver that makes it only update every tens of metres if in that mode (to smooth out the error in location), and another mode that continuously updates (because the SirfIII have smaller positional errors)? |
The GPS itself has nothing on it, apart from the power button, LEDs and charging socket, does anyone know how to change modes through TT, if you can? |
Posted: Tue Aug 23, 2005 3:05 pm Post subject: |
I thought you could access features from your PC via bluetooth and programs like SirfDemo |
Posted: Tue Aug 23, 2005 9:57 pm Post subject: |
cootuk wrote: | I thought you could access features from your PC via bluetooth and programs like SirfDemo |
The GPS manual consists of a pretty picture explaining the buttons, etc and that's about it! |
Posted: Tue Aug 23, 2005 10:59 pm Post subject: |
dhevans_6 wrote: | cootuk wrote: | I thought you could access features from your PC via bluetooth and programs like SirfDemo |
I've tried SirfDemo, changed the option,
More responsive now,
lbendlin Pocket GPS Staff
Posted: Tue Aug 23, 2005 11:27 pm Post subject: |
Some of the SiRF receivers have "Static Navigation" enabled. This is the problem, and it can be fixed with SiRFDemo. _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Wed Aug 24, 2005 9:45 am Post subject: |
My TomTom MkII receiver had Static Navigation enabled,
Search the net for SiRFDemo and you should find it on a forum with some instructions for use,
WARNING:
Playing with the settings can make the receiver stop working,
Use caution when using the program,
I at one point thought I'd screwed my TT receiver up, but I'd just forgoten to change it back to NMEA mode,
Posted: Wed Aug 24, 2005 10:12 pm Post subject: |
Ah yes, it explains that under a certain speed, your position won't update within a certain range.
Annoying I can't switch it at will in the car though... |
Posted: Thu Aug 25, 2005 12:16 am Post subject: |
dhevans_6 wrote: | Ah yes, it explains that under a certain speed, your position won't update within a certain range.
No, it's an embedded option in the Sirf chip set,
Unless someone does a Phone version of Sirfdemo,
