SteveW Frequent Visitor
Joined: 21/05/2003 22:54:59 Posts: 516 Location: Leicestershire UK
Posted: Sun Sep 14, 2003 8:04 am Post subject: newbie probs with setting favourites |
The problem with favorites is that if your PDA crashes, you could loose them all. Keep them as a POI file, and you will not loose them.
Steve |
footman Regular Visitor
Joined: 05/06/2003 06:48:54 Posts: 150 Location: Camberley, Surrey
Im using TT2.24(fully upgraded) on Ipaq 3660.Im having problems in setting favourite locations.It tells me to press and hold map view but all that does is recycle me through the navigation options.Im obviously missing something vital(story of my life!).
be grateful for help
Laurence |
DavidW Pocket GPS Moderator
You need to tap and hold in the Map screen (not the Navigator screen) to set a favourite.
If I want to set a POI (I prefer to use a Personal POI category rather than favourites) when I'm driving, and hence in the Navigator screen, I do it as follows.
I have a hardware button mapped to "Memorise location", and I press that at the location.
Later, when I'm stationary, I go into the Map screen, and use Find, Recent Locations to recall my memorised locations. I can then add them as favourites or POIs as I wish.
Does that help?
David |
catken96 Occasional Visitor
Joined: 14/06/2003 13:41:20 Posts: 41 Location: United Kingdom
Hi Laurence,
IF you mean an itial setup,I would suggest that you set Favourites as follows:- In "MAP" tap the icon to the right of A/B, (magnifying glass), tap "ADDRESS" icon (yes, the the magnifying glass again!), in "CITY" type the name of the Borough, Village, Town, or City that has the address you require, type in "Street", and House No. if applicable. Tap "OK". In the box that opens on Map, you will see the name of the road/street with it's postcode.Tap on "Add to favourites..." and there you are!!!!(hopefully). You will also notice other options in the box-- Navigate to, Set as departure/destination, and Show on map. Don't forget to make your Home address the FIRST entry in favourites. If I've mis-understood you, and I'm teaching your Grandmother to suck eggs, my apologies.
Tom. |
thanks for the advice
Laurence |
