Pocket GPS World :: View topic - Speed Camera files for Ipac 1710 + Tom Nav 5..help
whu64t
PostPosted: Tue Aug 23, 2005 9:23 am    Post subject: Speed Camera files for Ipac 1710 + Tom Nav 5..help Reply with quote
Can anyone help a idiot...I have just got yhe aboth and have downloaded the speed Cameras files
Tried copying the ov2 bmp files(downloaded from here) onto my SD in GT Britain, managed to copy some files
On the other files I get the following error messgae
Cant convert pocketgps_uk_gatso the drive cant find the sector requested
I am using the right files, do I need all these files...
Any help and how do I get them enabled
Thank You for any help
whu64t
PostPosted: Tue Aug 23, 2005 10:27 am    Post subject: Reply with quote
This might help you. It sounds like your trying to add the wrong file type.
There can be 3 setups for speed cameras.
The first is a single file that contains all the cameras together, without any reference to what type. This is named pocketgps_uk_sc.ov2 and found in the 'single file version' folder.
Second is the 5 file version that divides the cameras into types. Gatso, Mobile, Specs, Redlight and Temporary. These you will find in the 'ov2 bmp' folder.
Third is the full 17 file version that divides the Gatso and Mobile files into speed zones. There are 7 each of the Gatso and Mobile files. These are found in the 'speed zoned/gatso/ov2 bmp' and speed zoned/mobile/ov2 bmp' folders. Add to these the Specs, Redlight and Temporary files as above.
I have not included the Continental file because you will only need this if going to the continent.. But should you want it , it's in the 'ov2 bmp' folder.
When you've decided which set you want copy each .ov2 file, and it's matching .bmp file to your map folder. Then setup the POI's in Manage POI.
whu64t
PostPosted: Tue Aug 23, 2005 3:31 pm    Post subject: Reply with quote
Thanks for coming back to me, I tried to copy the 5 files and thats was when I got the error message...
I was copying the file and then pasting into the directory...the bmp files are okay but the ov2 files wouldn`t copy....should I be copying this way or using something else
whu64t
PostPosted: Tue Aug 23, 2005 5:01 pm    Post subject: Reply with quote
Were you copying them one at a time, or selecting all 5, and then pasting?
Try them one at a time and see which one is the problem.
22.071 (03 Jul 24)
