Stanley_Tweedle Regular Visitor
Posted: Mon Aug 22, 2005 11:05 pm Post subject: Search on Street Name Only |
Is it possible to search on Street only, ie if you don't happen to know the actual city the road is listed under, can I search the whole country and then select from a list? |
rkm_hm Frequent Visitor
Joined: Nov 28, 2004 Posts: 532 Location: Warwick, UK
Posted: Mon Aug 22, 2005 11:59 pm Post subject: |
No, but you can search on postcode if you know that.
If you don't know which city the road is in, how will you know you have the right one, anyway? _________________ Roger
TomTom via135
Satmap Active 10+ v1.50 with full UK 1:50k map and 1:25k/1:10k County maps of Hampshire & Warwickshire |
Posted: Tue Aug 23, 2005 2:12 pm Post subject: |
I think it would be useful, it might not always be clear which City a particular road is registered under, out in the sticks it could be a matter of opinion (ie you have been given the wrong city). It is possible that you may have been given just a road name and no city at all.
As to how you'd know you had the correct one I think the general locallity when selecting from a list would confirm in most cases. |
Posted: Tue Aug 23, 2005 8:35 pm Post subject: |
OK, just imagine telling it to navigate to "High Street".
How are you going to sort through the literally thousands of possibilites in order to select the one you want? _________________ Roger
TomTom via135
Posted: Tue Aug 23, 2005 9:21 pm Post subject: |
Yes in some cases it would not be practical that's why I said most cases. |
Posted: Tue Aug 23, 2005 10:11 pm Post subject: |
I suspect that it wouldn't be practical in most cases - and that there are too few instances where it would be useful for TT to consider implementing it. _________________ Roger
TomTom via135
Posted: Tue Aug 23, 2005 10:32 pm Post subject: |
Well I suppose my question was answered in that it isn't implemented. Thanks for the replies everyone. |
lbendlin Pocket GPS Staff
Posted: Tue Aug 23, 2005 11:32 pm Post subject: |
Just to throw in the american perspective. Over here searching by street name is the preferred method, and most american users are very irritated that TomTom does not offer that feature when most of the competition does have it.
With Suburbia spreading and no obvious town or city borders it is extremely difficult to know the city name or zip code.
Granted, we don't have High Streets over here... _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Wed Aug 24, 2005 1:21 am Post subject: |
That's interesting indeed. I know infomap navigator allows it and I wondered about other systems too. In USA there must be a huge no of streets.
I thought of one idea that may make things easier in that the street list could be sorted by distance (I think POI's are already handled this way?) from the current position or another specified location. That may take an unreasonable amount of CPU time, not sure (maybe straight line distances would do).
I suppose for some reason I have the impression that I will get stuck not knowing the correct city; I have seen other posts mentioning that there are differences between local authority boundaries and postal areas etc.
TT have probably found it is not worth implementing; I suppose I would feel happier if it was there even if it turned out to be useless! |
Posted: Wed Aug 24, 2005 1:29 am Post subject: |
It's also a real problem in UK - particularly in large cities like London, where a road may be listed as belonging to London or to any one of several adjacent suburbs. But you've got to know more or less where a road is if you are to have any chance of navigating to it. Just wind the clock back a bit, and think how you'd navigate to somewhere using a paper map if all you knew was a road name which could be anywhere in the country.
You may not have too many High Streets in USA - but you've probably got a lot of West 42nd Streets or somesuch!
In UK we have a Postcode system - broadly similar to ZIP codes but with much finer granularity - such that a full 7-character postcode pinpoints a location to within a hundred metres or so. In my view, the only reliable way to navigate to an address in the UK is to use this postcode - because it is unique to a very small area and eliminates all the uncertainties and ambiguities of street names.
The latest TT maps let you do just that - without needing to know city, etc. _________________ Roger
TomTom via135
Daggers Lifetime Member
Joined: Jun 20, 2005 Posts: 1096 Location: Solihull, UK
Posted: Wed Aug 24, 2005 2:37 pm Post subject: |
Some years ago, while working for a large UK utility company, I had to conduct an analysis of its customer addresses. Many errors were found, mainly due to inaccuracies in the information supplied by the customers. The main problems were:
1. Incomplete addresses
2. No postcode provided
3. The address containing the wrong town (or no town at all)
This last issue tended to be caused by a certain amount of snobbery ("I don't live in xxxxx, I live in yyyyy - it's a much nicer place"). It was particularly prevalent in large conurbations where suburbs run into one another, or in villages situated just outside larger towns.
My point is that in many cases, if you are trying to navigate to a place, and you haven't been given the correct information, then you are going to have difficulties. Being able to searching by street name would be a useful addition to the TomTom software, although it may not necessarily be the most frequently used.
However, just to add more confusion, be aware that it is not unknown for there to be two streets with the same name within one town - or even within the same postcode area! |
Posted: Wed Aug 24, 2005 10:04 pm Post subject: |
Daggers wrote: | However, just to add more confusion, be aware that it is not unknown for there to be two streets with the same name within one town - or even within the same postcode area! |
The same postcode area perhaps - but presumably not with all 7 characters of the postcode being identical?
Did you find that identifying the correct postcode was by far the best way of sorting your addressing problems? _________________ Roger
TomTom via135
Posted: Fri Aug 26, 2005 1:24 am Post subject: |
Quote: | The same postcode area perhaps - but presumably not with all 7 characters of the postcode being identical? |
Yes - thats correct. The 6/7 character postcode covers, on average, only around 15 properties and, in theory, they should all be in the same physical street. Two different streets, even with the same name would have a different full postcode.
Quote: | Did you find that identifying the correct postcode was by far the best way of sorting your addressing problems? |
The problem we were trying to solve was actually quite different to navigation. We were trying to get the postal addresses correct so that we could maximise postage discounts from Royal Mail. In this case, postcode was most important, so we could sort the bills into an order most convenient for the Royal Mail, but it was also important to get the street name and postal town correct, along with other data, to create a more professional image. |
Posted: Fri Aug 26, 2005 11:35 pm Post subject: |
Daggers wrote: |
Although your problem was not navigation, it seems to me that it has some things in common with navigation - primarily that for both you need a unique location key. In the UK, postcode is by far the most reliable key for these purposes. In your case, once you got the postcode right, all the other address details followed automatically from the Royal Mail database.
For navigational purposes, each postcode is linked to a pair of latitude/longitude co-ordinates - so once you know that, you can be sure of going to the right Acacia Avenue in the right town.
Going back full circle to the original question about searching by street name without knowing the town, there is a sense in which TTG already does this. You do need to know more or less where it is, but if you guess the wrong town, it will display similar roads in nearby towns.
For example near where I live in Warwick there is a road called Wathen Road. In Leamington Spa, there is a differentWathen Road - about 3 or 4 miles away. If I ask TTG to navigate to an address and specify Warwick and then Wathen Road, it displays both Wathen Roads. The only problem is that it identifies them by postcode - one being CV34 5 and the other being CV32 5 - so this is another good reason for finding out the postcode of your intended destination! _________________ Roger
TomTom via135
Posted: Sun Aug 28, 2005 11:44 am Post subject: |
Yes we are part of the way there with town names that seem to be linked back to the city name. All we need now is to remove the city name barrier.
I enter my best guess at the city/town name, enter a street name and I get a sorted list (by distance from that city), maybe have a limit as to how many streets will be displayed, possibly 10, 15 or whatever is practical . If I don't enter a city the list can be sorted from my present location.
Postcodes are suberb but there are cases when they won't be available (taxi customers for example). Also they are not supported for most countries.
It 's not a great idea to set off somewhere if you aren't totally sure you have the correct destination; all I'm suggesting is a tool to help us find that; the human brain is very good at picking up on any additional information available; just browsing the surrounding area on the map may be enough to confirm it is Out in the Sticks Road A as opposed to Out in the Sticks Road B. |
