Pocket GPS World :: View topic - Help Needed with connecting to tomtom services
unders
PostPosted: Mon Aug 22, 2005 11:10 pm    Post subject: Help Needed with connecting to tomtom services Reply with quote
I have recently bought the tomtom HP 2110 navigator system.
I have followed the instructions on how to connect to services ( weather, traffic ) but i am having no luck connecting.
I have gprs activated phone and i have paired all bluetooth devices up yet i cant get anything when i am on the move.
i have signed up for 30 day free trial of tt plus and it is activated as i checked by plugging ipaq into my pc whilst connected to the internet.
But when i am mobile, it does not connect to the server.
WHAT AM I MISSING !!! i am sure it is something simple.
PLEASE HELP ME !!
THANKS
UNDERS
unders
PostPosted: Mon Aug 22, 2005 11:25 pm    Post subject: Reply with quote
HOW DO I CONNECT IT TO THE INTERNET WHEN MOBILE
Rambler358
PostPosted: Mon Aug 22, 2005 11:42 pm    Post subject: Reply with quote
You might want to check that your cell phone has GRPS service while you're on the move. Does Navigator attempt a GPRS connection? What are the time intervals you have updates set to?
unders
PostPosted: Mon Aug 22, 2005 11:54 pm    Post subject: Reply with quote
hi,
It does have service on the move ( my phone )
even when i try to connect to internet on ipaq ( eg. messenger ) it says i have no modem set up.
itjust doesn't want to connect. do i need more hardware or do i need to set something up on the ipaq. pls spk to me like a beginner.
unders
PostPosted: Mon Aug 22, 2005 11:56 pm    Post subject: Reply with quote
it says that it is trying to retrieve but connot connect to server.
I think i need to set some sort of connection up but dont know how
Rambler358
PostPosted: Tue Aug 23, 2005 12:26 am    Post subject: Reply with quote
Can you retrieve email from Messenger while you're on the move? It sounds like some kind of connection issue that's not specific to TomTom Navigator. I'd try and get that resolved first. Since I'm not familiar with your IPAQ device, I can't really help you out with that. There should be plenty of forums where you can get help with connection issues though. Once you've got that resolved, you shouldn't have any problems with TT Navigator. Good luck!
unders
PostPosted: Tue Aug 23, 2005 12:29 am    Post subject: Reply with quote
please help !!!
trying desperately to connect to internet via ipaq.
how!!
can i do it thru phone, if so, what do i do???
my phone is totally gprs ready
unders
PostPosted: Tue Aug 23, 2005 12:32 am    Post subject: Reply with quote
i see !!!
just need to know how to connect ipaq, i have no idea.
it said in instructions that i just needed gprs ready phone but there is obviously something i need to set up on ipaq.
is that correct
brob108
PostPosted: Tue Aug 23, 2005 12:36 am    Post subject: Reply with quote
Can you connect to the Internet via Active Sync? If you can try the TomTom services via Active Sync also. If they work then it looks like a pairing issue with your phone/IPAQ or check again with your mobile operator that GPRS is properly set up on your account.
Which operator are you with?
I had trouble with my GPRS account until I contacted O2 directly and it all got sorted.
unders
PostPosted: Tue Aug 23, 2005 1:13 am    Post subject: Reply with quote
Yes i can do that via active sync.
I am on vodafone and i rang them but they isaid i was gprs ready and that would do it.
still no luck
any ideas?????
unders
PostPosted: Tue Aug 23, 2005 1:37 am    Post subject: Reply with quote
i can do everything via activesync.
what is the best way for me to connect via my ipaq when on the move???
Rambler358
PostPosted: Tue Aug 23, 2005 5:02 am    Post subject: Reply with quote
You need to get the connection string from your phone carrier. Put that connection string into your Bluetooth manager settings. Again, I'm not familiar with your PPC device or your carrier so I can't help any more. But you should contact Vodafone and ask what connection string you should use.
SteveW
PostPosted: Wed Aug 24, 2005 1:37 pm    Post subject: Reply with quote
The area you need on your PDA is probably around "Start", "Settings", "Connections", "New",
Enter a Name such as "Mobile Connection"
Select a Modem "Bluetooth Dial-up Modem"
Select Baud Rate of "57600"
Select "Advanced"
Here you need the Vodafone information. The number to dial will be something like "*99#" The extra dial-string modem commands will be something like "+CGDCONT=1,"IP","VODAFONE.CO.UK"
I don't know if Vodafone uses Server assigned IP ADDRESS or not.....BTMobile does, but O2 when I used them did not.
You may be able to find more help by searching the site, I have seen this question raised before.
Hope this helps,
Steve
Talkingbollox
PostPosted: Wed Aug 24, 2005 3:16 pm    Post subject: Reply with quote
Once you've paired your phone to the PDA, have a look at the gprs settings for your carrier http://www.filesaveas.com/gprs.html
