marku Occasional Visitor
Posted: Sun Aug 21, 2005 10:14 pm Post subject: GH-101 mount + TTN 5 |
Has anyone got problems with the GH-101 mount, mine takes an age to get a fix. Sometimes upto 15 minutes. I don't know if it is the mount or the upgrade to TTN5 (i bought the mount and upgraded to TTN5 at he same time).
If i plug the mount in and power up for 5 minutes or so and then plug my hp2210 in its ok. Occasionally it loses its way on the road even though i have 4 -5 bar signal strength. the pointer is the middle of nowhere and then the road appears and it's back on track.
I don't know if it is the mount or the software.
Has anyone any thoughts.
Thanks |
EasyD2 Regular Visitor
![](modules/Forums/images/avatars/1657901726438c327304bf8.gif)
Posted: Tue Aug 30, 2005 11:08 am Post subject: |
What settings are you using in the TomTom software? _________________ www.easydevices.co.uk
Tel: 0871 7000 156
Globalsat UK Distributor |
Posted: Sun Sep 04, 2005 12:33 pm Post subject: GH-101 |
Hi sean,
My setting in Tomtom5 are Other Cable NMEA GPS, Baud rate 4800.
i believe it to be the software rather than the mount, because the screen seems to occasionally lose roads then finds them again yet the Satellite signal stays around 4 bars. I used to have TTN3 and a wired Tomtom Gps and didn't have a problem waiting for a signal to be found.
The mount is has close to the windscreen as possible. (Not heated)
Mark |
alix776 Pocket GPS Moderator
Posted: Sun Sep 04, 2005 1:38 pm Post subject: |
try leaveing the everything pluggd in and move the mount out of the car still plugged in and see if the signal changes if it gets better then you have an athermic wind screen _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
