Pocket GPS World :: View topic - HAICOM 303 with IPAQ 3760
marco963
PostPosted: Sun Sep 14, 2003 8:04 am    Post subject: HAICOM 303 with IPAQ 3760 Reply with quote
I have incredible problems to integrate a Seidio DUAL CF with a CF 128 Sandisk and a Haicom 303 GPS (SW Destinator and TomTom 2). GPS works (standalone), CF files are accessed normally but when SW tries to match the position with the map archived on CF, IPAQ freezes and I must reset it). What kind of conflict is this and how could I solve it ?)
DavidW
What happens if you try to plan routes and so on with the iPAQ without the GPS card inserted? Planning routes, panning the map and similar operations will all use the CF card heavily, and this should reveal whether things are stable with the memory or not.
If things are not stable without the GPS card inserted, then your problem is seemingly with the memory card or the expansion pack.
If they're stable with just the memory, then you may need to delve a bit deeper. It could be the expansion pack. If the system is stable when heavy use is being made of the memory, I'd be tempted to get hold of the Haicom cable for your iPAQ and try with the GPS hooked up to the serial port to see if that helps.
My Haicom HI-303MMF works perfectly in my HP/Compaq PC Card Expansion Pack Plus (and a Pretec PC Card / CompactFlash adapter) on my 3970 - so the Haicom isn't completely broken in CompactFlash mode. I admit, though, that my hardware is very different to yours.
22.062 (12 Jun 24)
