Pocket GPS World :: View topic - TomTom GPS Hardware
TomTom GPS Hardware
dogo
PostPosted: Sun Sep 14, 2003 8:04 am    Post subject: TomTom GPS Hardware Reply with quote
Hi can anyone tell me the meaning of the Flashing LED/Light on the GPS reciver. currently it flashes orange a lot! and then Flashes Green..
dogo
RichDem
when it is flashing orange it is trying to get a fix, when it flashes once a second it has a 3d lock, when it flashes twice a second it only has a 2d lock.
Hope this helps
dogo
cheers for the info! In that case i often get two green flashes per second Smile, from time to time i do get one green flash...but i cant get TT2.2 to register the device... any ideas
dogo
DavidW
Assuming you've selected the right serial port in the TomTom GPS driver (on almost all Pocket PCs, it should be COM1:), the right sort of GPS and the box next to those two settings on the second tab of the GPS driver contains a tick (if not, tap on it) - are you running a keyboard driver on your Pocket PC. If so, disable the keyboard driver.
Other possible solutions include a faulty cable or GPS, the cables not connected together correctly (not firmly located?), damaged serial port on the Pocket PC, or you've mistakenly connected an iPAQ 3800/3900/5000 series cable to an iPAQ 1910 (which won't work as the 1910 has no serial port).
22.055 (29 May 24)
