pcb007 Regular Visitor
Posted: Wed Jul 20, 2005 10:56 pm Post subject: Tom Tom and C550 |
Hi, i have heard that Tom Tom 4 does not work on the SPV C550, but does anybody know if it works ok with Tom Tom 5? |
carmex Regular Visitor
![](modules/Forums/images/avatars/37868368042c3b0d353312.jpg)
Posted: Thu Jul 21, 2005 12:08 pm Post subject: |
It's not listed by TomTom as a supported device, and neither is the Qtek 8100 which is essentially the same SmartPhone - they have a different screen resolution to the C500, SP3 etc so perhaps it's going to take a patch to make it compatible at a later date?
Owen
Product Manager
www.globalpositioningsystems.co.uk
YooNoo LTD _________________ owen.haigh@yoonoo.co.uk
www.globalpositioningsystems.co.uk - GPS System Specialists |
Posted: Sat Jul 23, 2005 3:33 pm Post subject: |
For anyone that is thinking of upgrading to the C550 just to let you know that Tom Tom does not work on it. Screen resolution is to big. As suggested a patch may become available, but knowing Tom Tom god only knows when that will be. |
thunderz2000 Occasional Visitor
Posted: Fri Aug 05, 2005 12:22 pm Post subject: |
i have it working on a c550. But u will need mobile registry editor...a strong heart and a few alterations later within the registry and tom tom runs fine at the moment on the c550. Temprarily until the patch appears
reagrds |
Darren Frequent Visitor
Posted: Fri Aug 05, 2005 1:09 pm Post subject: |
Care to share details of what registry changes are required? _________________ Darren Griffin |
Posted: Sat Aug 06, 2005 9:44 am Post subject: registry changes |
ok darren this is what you need to do
first off you need to have mobile registry editor on the phone.
or a decent registry editor.
1. Open the reg editor and go to HKLM and select drivers
2. Then select display and open that
3.Your are then faced with GPE open that
4. Then select Values from the menu and open it
5.select Logical pixels X
6. Select Value data and alter it to 138 select done
7. Select Logical pixels Y and also alter value data to 138
select done and switch off the phone
Restart the phone
You should now see useable menus not to different from before but now in the interim Tom Tom should be very useable
HOpe it works for you as it has for me
Regards
Hawk |
Posted: Sat Aug 13, 2005 1:54 pm Post subject: |
Hi i have tried out your changes but i keep getting Operation cannot be carried out, do u know y this is so?
Paul |
Posted: Tue Aug 16, 2005 8:53 am Post subject: |
Sorted it, phone had to be totally unlocked. Works a treat now, looks even better on the C550 then the C500 :D |
dasut Occasional Visitor
Joined: Nov 08, 2004 Posts: 3 Location: Wolverhampton
Posted: Fri Aug 19, 2005 12:53 am Post subject: |
What do you mean by unlocking the phone?
Is that to all network ![Question](modules/Forums/images/smiles/icon_question.gif) |
Posted: Fri Aug 19, 2005 8:49 am Post subject: |
No, he is referring to the 'Application Unlock' which is different. _________________ Darren Griffin |
Posted: Fri Aug 19, 2005 8:50 am Post subject: |
No the phone has to be application unlocked. It seems to come preset with the ability to use some programs and not others. So it has t be application unlocked in order to be able to use the regsitry edit program, otherwise you cant change the values. The unlock is normally straight forward to do via the Orange Web site. |
awarner Occasional Visitor
Posted: Fri Aug 19, 2005 10:56 am Post subject: |
Don't forget while this works, you are also turning the C550 into a C500 with a few extra buttons, also this will alter the display until you alter the registry again. So you would need to alter the registry back and forth every time to still get the best out of the phone and use TomTom as well.
This has been discussed in more detail here
http://www.modaco.com/C550_TomTom_FIX-t224265.html _________________ Life's too fast can I get off and walk for a bit?
Microsoft MVP Mobile Devices
MoDaCo.com Staff Team Leader |
Posted: Fri Aug 19, 2005 1:17 pm Post subject: |
Thanks.... got the application lock sorted...fairly quick and easy.
Which version of TomTom Mobile works on SPV C550.. ![Wink](modules/Forums/images/smiles/icon_wink.gif) |
Posted: Fri Aug 19, 2005 2:14 pm Post subject: |
Preferably the version you have bought. TomTom Mobile 5. _________________ Darren Griffin |
Posted: Fri Aug 19, 2005 10:00 pm Post subject: |
Yes...TomTom Mobile 5.000 does work. The version i have 8) |
