Artisan Occasional Visitor
Posted: Thu Aug 18, 2005 10:51 am Post subject: Is It TTN 5 or my Rikaline CF that's playing up? |
I’ve been having a few problems with TTN 5 recently. The first being time to first fix, which is dreadfully slow sometimes 20 mins or more. I’ve set the GPS correctly IE ‘other cable NMEA GPS’, ‘baud rate 4800’, Rikaline_CF.
Secondly when I do get a fix even with all 5 bars showing it seems to intermittently drift all over the place or suddenly loose GPS connection altogether. Yesterday it sent me off on the M42 when I should have stayed on the M6.
TTN 4 worked fine without to many problems, but with TTN 5 and all the problems encountered it’s difficult to determine if it’s TT or the Rikaline is on it’s way out. I haven’t downloaded the recent TTN 5 patch yet so will that cure it?
Thanks in advance.
Art
_________________ TomTom Via 135 |
lbendlin Pocket GPS Staff
Posted: Thu Aug 18, 2005 11:54 pm Post subject: |
Use another program (eg Mapopolis) and see if you have the same positioning issues. _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
longwori Regular Visitor
Joined: 15/04/2003 12:14:36 Posts: 151 Location: Cheshire, UK
Posted: Fri Aug 19, 2005 12:27 am Post subject: |
I have a CF GPS and the 5.1 patch seemed to imrpove the reliability of the GPS reception. I think they made a hash of the GPS driver in 5.0.
Apply the patch and I think you will be OK.
Ian _________________ TomTom Go 520, HTC Wildfire with CoPilot Live Premium UK & CoPilot Live Standard USA |
Posted: Fri Aug 19, 2005 9:08 am Post subject: Re: Is It TTN 5 or my Rikaline CF that's playing up? |
"Yesterday it sent me off on the M42 when I should have stayed on the M6. "
I had this happen a couple of times so its probably a bug in the software - I assume you were heading East (I was), fortunatly I ignored what the TT was telling me to do, but if you don't know the area its an easy and costly (in time terms) mistake - Mike |
swanpa01 Occasional Visitor
Posted: Fri Aug 19, 2005 9:10 am Post subject: |
Also ensure you have the external aerial connected. Even though it worked fine without on TT v4 it is still required for TT v5 - updating to 5.1 does improve things slightly but it's far better with the aerial
Paul |
Posted: Fri Aug 19, 2005 2:06 pm Post subject: |
I’ve now upgraded to TTN 5.1 and there seems to be a slight improvement however it still seems to go from 4 bars to 1 bar quiet frequently and still drifts. I’ll have to buy an aerial and try it.
Thanks for all the help ( as usual ).
Art
hogbreath Regular Visitor
Joined: Feb 07, 2004 Posts: 139 Location: Hillingdon, Middx
Posted: Sat Aug 20, 2005 12:16 pm Post subject: |
Can only agree with the comment made about the bars going up & down like a yoyo when compared to tt3 Gps2.06 driver - rock solid usually between 3-7 sats at any one time.
Are the tt5 bars number of sats or signal strength?
Pete
IPaq_2210 rom upgrade 1.10
ttn v3.03(427)/ Gps v2.06 / Viking cf 256mb & Kingston cf 1Gb x 2
CheckPOint v2.02
Socket BT gps
Spb Pocket Plus v2.1 Build 1545
Fugawi PPC v1.6
PHM Registry Editor v0.70
Pocket Mechanic v1.49
Digitools Ukpostcodes
Active Sync 4.0.0 Build 3244
Sprite Backup v3.01 Build 1676 |
