Pocket GPS World :: View topic - Car mount for iPAQ h2210
Mermaid
PostPosted: Fri Aug 05, 2005 10:35 pm    Post subject: Car mount for iPAQ h2210 Reply with quote
Hello
I've had an Arkon vent mounted holder for my iPAQ for the last year, but today it sheared off completely leaving just the prongs in the vent! Must be the vibration in the car. Confused
Anyway, it has put me off getting another Arkon, so can anyone recommend something? I'd like another vent mounted one as it is in the perfect position. I don't want a powered unit though, as I have a separate GPS receiver that often needs charging at the same time as my iPAQ (at the moment I can plug both into the one cigarette lighter). I don't want it to do anything flashy apart from hold the iPAQ!
Thanks. :D
iPAQ h2210
TomTom Navigator 5.21 Bluetooth
Nokia 6230
PostPosted: Sat Aug 06, 2005 9:15 am    Post subject: Reply with quote
Get a Brodit, forget the vent and use one of their ProClips to fix it to the dash without any drilling etc. They have one with an amplified speaker which works well.
They are by far the best mounts available, we've reviewed a few to give you an idea what they're like, I have a 2210 mount in my Disco, see here for a photo.
Goto www.brodit.com to choose your mount and ProClip then order in the UK from www.handnav.co.uk .
Mermaid
PostPosted: Tue Aug 09, 2005 2:48 pm    Post subject: Reply with quote
Thanks for the advice Darren, they look a lot better than what I've been using.
iPAQ h2210
Nokia 6230
tommo123
PostPosted: Sun Aug 14, 2005 12:23 am    Post subject: Reply with quote
Darren do you have the hard wired brodit mount with a plug for the gps?
PostPosted: Sun Aug 14, 2005 9:40 am    Post subject: Reply with quote
I do, I use the PS/2 cable with a PS/2 - RJ11 converter to allow me to plug in a GPS Mouse or alternatively I use the Brodit PS/2 to TomTom charging cable to top up my BT units.
ashleey
PostPosted: Tue Aug 16, 2005 9:52 pm    Post subject: hard wire cable plug? Reply with quote
Is the hard wire cable with the Brodit Active mount fixed to the mount, or is it a plug connection?
I already have a hardwire cable (12/24V)set up in my car but would like to plug it into a better mount than the Seidio G2500 I currently use, as it is far too bulky and I don't need a speaker but would like to charge my TT Bluetooth GPS receiver from the mount using the charging cable that fits the Seidio.
Thanks in advance for any help
PostPosted: Tue Aug 16, 2005 9:55 pm    Post subject: Re: hard wire cable plug? Reply with quote
Not sure which cable you are referring to? The main power cable to the mount is fixed, the accessory charge lead running from the PS/2 connector is not.
ashleey
PostPosted: Tue Aug 16, 2005 11:07 pm    Post subject: best active mount hp ipaq 2210 Reply with quote
In that case, what would be the best active mount to connect to my existing hard wired power cable?
I don't need a speaker but would like to occasionally charge my TT bluetooth GPS receiver, and would like the slimmest solution to fix to my Brodit Proclip.
Is it a Brodit pass through mount?
PostPosted: Tue Aug 16, 2005 11:29 pm    Post subject: Reply with quote
What type of connector does your hartd wired cable teminate in?
ashleey
PostPosted: Wed Aug 17, 2005 10:01 am    Post subject: power connector to seidio g2500 Reply with quote
It is the usual 3mm jack connector, i.e. not an ipaq connector.
Thanks for the help, I just feel I need to get a good mount now that the 2210 is last year's model.
Would any of the new ipaq hx models have the same dimensions and connections?
23.061 (04 Jun 25)
