Pocket GPS World :: View topic - Speed Cam Database for SmartST 2005
antispam
PostPosted: Tue Aug 16, 2005 9:51 pm    Post subject: Speed Cam Database for SmartST 2005 Reply with quote
Incase i get stuck using SmartST 2005 on my Navman 570...........
I know there are speed cam databases for other versions, but my question is......
Is there a version and if so which one will work with Navman 570 / SmatrST 2005
Paul
Tim Buxton
PostPosted: Tue Aug 16, 2005 10:01 pm    Post subject: Re: Speed Cam Database for SmartST 2005 Reply with quote
Paul
Use the \csv\other files. Edit them in Notepad by adding a; to the beginning of the top line. Then use the Navman Desktop POIEditor programme to import them into your device.
Tim
antispam
PostPosted: Tue Aug 16, 2005 10:06 pm    Post subject: Reply with quote
Do you have a link where i can download.. Navman Desktop POIEditor
Tim Buxton
PostPosted: Tue Aug 16, 2005 10:08 pm    Post subject: Reply with quote
If you install the Navman Desktop onto your PC, POIEditor is part of the package. Click on Map, then Points of Interest.
Tim
antispam
PostPosted: Tue Aug 16, 2005 10:13 pm    Post subject: Reply with quote
Sorry for double posting Tim.
Ok you mentions something about... " Edit them in Notepad by adding a; to the beginning of the top line. "
below is a copy of the Continental d/base for example purposes...
Longitude,Latitude,Name
6.15003,46.22089,"CHF:001"
6.15175,46.24400,"CHF:002"
3.63020,51.48500,"NLF:001"
3.83860,51.31660,"NLF:002"
4.26060,52.05160,"NLF:003"
4.30730,51.84930,"NLF:004"
4.34070,52.06260,"NLF:005"
4.41550,51.92320,"NLF:006"
4.45310,51.86630,"NLF:007"
4.49470,51.54070,"NLF:008"
4.50360,52.03630,"NLF:009"
4.50540,52.14530,"NLF:010"
4.53930,51.93270,"NLF:011"
4.65820,52.38930,"NLF:012"
4.67380,52.02540,"NLF:013"
4.68830,52.29050,"NLF:014"
4.70310,51.80400,"NLF:015"
4.75310,51.59820,"NLF:016"
4.77120,52.62620,"NLF:017"
4.83700,52.39600,"NLF:018"
4.90530,52.07690,"NLF:019"
4.93480,52.36790,"NLF:020"
4.94120,52.30180,"NLF:021"
4.98720,51.83870,"NLF:022"
4.99710,52.51650,"NLF:023"
5.04430,51.53800,"NLF:024"
5.04550,52.11760,"NLF:025"
5.04920,51.67870,"NLF:026"
5.11380,52.04830,"NLF:027"
5.14300,52.12330,"NLF:028"
5.14480,52.22000,"NLF:029"
5.26740,52.39600,"NLF:030"
5.33960,51.70900,"NLF:031"
5.37570,51.38780,"NLF:032"
5.41740,52.17960,"NLF:033"
5.50440,51.43750,"NLF:034"
5.51040,51.73490,"NLF:035"
5.62600,52.03390,"NLF:036"
5.63990,51.47710,"NLF:037"
5.71290,50.87370,"NLF:038"
5.80650,51.84100,"NLF:039"
5.81010,50.99650,"NLF:040"
5.84230,53.19690,"NLF:041"
5.90180,52.96500,"NLF:042"
5.93270,52.19210,"NLF:043"
5.94360,50.90450,"NLF:044"
5.96040,51.97710,"NLF:045"
6.01500,51.20910,"NLF:046"
6.12690,52.48930,"NLF:047"
6.17840,51.39390,"NLF:048"
6.30230,51.94880,"NLF:049"
6.49030,52.73610,"NLF:050"
6.57000,53.00740,"NLF:051"
6.59600,53.21300,"NLF:052"
6.65220,52.33680,"NLF:053"
6.87910,52.22300,"NLF:054"
6.80974,51.17582,"DEF:001"
6.82504,50.96346,"DEF:002"
6.83161,51.19314,"DEF:003"
6.84015,51.22764,"DEF:004"
6.85401,51.23005,"DEF:005"
6.86019,51.16815,"DEF:006"
6.87898,50.94062,"DEF:007"
6.87996,50.95578,"DEF:008"
6.90059,51.02165,"DEF:009"
6.90321,51.02311,"DEF:010"
6.93577,50.96337,"DEF:011"
6.95150,50.90412,"DEF:012"
6.97303,50.93137,"DEF:013"
6.97984,50.96670,"DEF:014"
6.98081,50.95973,"DEF:015"
7.03194,50.98299,"DEF:016"
6.57920,51.48985,"DEF:017"
6.61735,51.34126,"DEF:018"
6.74549,51.26997,"DEF:019"
6.74549,51.27014,"DEF:020"
6.81025,51.25581,"DEF:021"
6.93138,51.46355,"DEF:022"
6.98010,51.38179,"DEF:023"
6.99182,51.39883,"DEF:024"
7.00712,51.43374,"DEF:025"
7.01209,51.47896,"DEF:026"
7.01616,51.41918,"DEF:027"
7.01848,51.46935,"DEF:028"
7.02486,51.41706,"DEF:029"
7.05834,50.96783,"DEF:030"
7.06156,50.93902,"DEF:031"
7.07094,50.92050,"DEF:032"
7.07448,50.94549,"DEF:033"
7.07532,51.37952,"DEF:034"
7.21137,51.30707,"DEF:035"
7.23582,51.39217,"DEF:036"
7.27157,51.35730,"DEF:037"
7.27695,51.35474,"DEF:038"
7.27869,51.31438,"DEF:039"
7.05997,51.43856,"DEF:040"
7.06107,51.41927,"DEF:041"
7.06151,51.46264,"DEF:042"
7.06439,51.46392,"DEF:043"
7.07182,51.46441,"DEF:044"
7.17697,51.41027,"DEF:045"
7.21527,51.42549,"DEF:046"
7.30513,51.43975,"DEF:047"
7.32324,51.50888,"DEF:048"
7.32416,51.51759,"DEF:049"
7.32550,51.49153,"DEF:050"
7.35423,51.40571,"DEF:051"
7.36888,51.43694,"DEF:052"
7.38803,51.52454,"DEF:053"
7.40141,51.48226,"DEF:054"
7.44670,51.52396,"DEF:055"
7.45308,51.47701,"DEF:056"
7.46803,51.49985,"DEF:057"
7.50740,51.50396,"DEF:058"
7.52031,51.56248,"DEF:059"
7.04240,51.93773,"DEF:060"
7.53785,51.55591,"DEF:061"
7.89940,51.46575,"DEF:062"
7.64544,51.79881,"DEF:063"
7.84822,51.77432,"DEF:064"
7.89840,51.77828,"DEF:065"
8.64947,51.68309,"DEF:066"
8.65565,51.68769,"DEF:067"
8.66694,51.75360,"DEF:068"
8.67886,51.69518,"DEF:069"
8.83149,51.71968,"DEF:070"
8.83463,51.72021,"DEF:071"
9.49333,51.25971,"DEF:072"
9.50436,51.26087,"DEF:073"
10.40955,53.56028,"DEF:074"
7.01696,51.45488,"DER:001"
7.31869,51.45900,"DER:002"
7.21918,51.46616,"DEM:001"
7.22310,51.45893,"DEM:002"
7.24136,51.47329,"DEM:003"
Where exactly do i put the " a; "
Sorry if i sond daft but i am daft :-)
But seriously thanks for your hlp, it's much appreciated
antispam
PostPosted: Tue Aug 16, 2005 10:16 pm    Post subject: Reply with quote
Also by using the CSV Files..... will i still see the little image of a camera like it did on tom tom 3 ?
Or do i have to install images seperatley ?
Tim Buxton
PostPosted: Tue Aug 16, 2005 10:18 pm    Post subject: Reply with quote
Sorry, I didn't mean a;, I meant a ;! Does that make sense?
Anyway, you put it at the beginning of the top line, thus.
;Longitude,Latitude,Name
Then save the file again. You must edit the files using Notepad though. .CSV files will open using Excel by default, but you can right-click the file and use 'Open with..' to get around this.
Tim
antispam
PostPosted: Tue Aug 16, 2005 10:24 pm    Post subject: Reply with quote
So i only need to put the ; before Longitude,Latitude,Name
with no space between ; and the Longitude,Latitude,Name
Blimey im confusing myself now :-)
antispam
PostPosted: Tue Aug 16, 2005 10:29 pm    Post subject: Reply with quote
Tim...
Ill give it a go tomorrow, ill sort it.
Going off track a little... did you read my post about the GPS receiver and TT5 using the navman 570 ?
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=26508
Maybe you have an idea ?
22.063 (19 Jun 24)
