Pocket GPS World :: View topic - Speed camera database on TomTom Mobile
steve6600
PostPosted: Mon Aug 08, 2005 5:19 pm    Post subject: Speed camera database on TomTom Mobile Reply with quote
I'm having trouble getting tomtom mobile to see the ov2 and bmp files. I have installed the (latest) files into the Great Britain map directory and selected "enable POI" in the "maintain POI" option but the software can't see them.
Has anyone had similar problems and know a fix Question
PostPosted: Mon Aug 08, 2005 7:09 pm    Post subject: Reply with quote
Have you loaded the Files or the Folders. If you loaded the Folders with the files inside, it won't work.
Incidently, I wouldn't 'Enable POI' for the cameras. This shows them on the Browse Map, and on the Navigating Map when the Warn When Near has not been set up.
Warn When Near is the better option. IMO.
TT Via 135 App 12.075: Europe Map v1140
MarkHewitt
PostPosted: Wed Aug 10, 2005 1:45 pm    Post subject: Reply with quote
Make sure you copy the files themselves directly into the map directory (Great Britain Navigator Map or similar). don't copy the directories.
Also make sure you completely exit TomTom (code 6-6-5) and then restart it.
aliendad
PostPosted: Wed Aug 10, 2005 1:52 pm    Post subject: Reply with quote
and hopfully, finaly, how did you copy the files?
dont use bluetooth, use a card reader.
PostPosted: Wed Aug 10, 2005 6:55 pm    Post subject: Reply with quote
The card reader is as good an option as any, and quicker generally.
geedee
PostPosted: Fri Aug 12, 2005 6:43 pm    Post subject: TTM5 Camera POI Reply with quote
I have just loaded TT5 and find that the Gatso etc database is found OK
but does not show up on the Maps ! as in previous version.
Any help welcomed.
Graham
PostPosted: Fri Aug 12, 2005 7:14 pm    Post subject: Re: TTM5 Camera POI Reply with quote
Any help welcomed.
Graham
Some more information will help us to help you.
What have you actually done? Which cameras have you loaded? Which Map do you mean, Navigation or Browse?
geedee
PostPosted: Sun Aug 14, 2005 9:35 pm    Post subject: Reply with quote
On TT Mobile prev version, I could see the Cameras on the Map View.
On TT5 this is not happening ,although as I approach a camera it shows up on the phone OK
(very strange).
I am not really worried as at least I am aware and the warning sounds all work OK.
Graham
flasher
PostPosted: Sun Aug 14, 2005 10:45 pm    Post subject: Reply with quote
simple solution
but tomtom into browse map mode
then click options,. then change preferences
you`ll most likely see "points of interest" not ticked
tick the option then click done
all should be fine from now on
iPhone 3Gs 32GB
using TomTom & CoPilot
Pocketgpsworld iphone cameralert app
MarkHewitt
PostPosted: Mon Aug 15, 2005 9:41 am    Post subject: Reply with quote
geedee wrote:
(very strange).
Graham
That's the way I've got it set up. I have all of the POI's disabled, but I have warnings enabled. So when I approch a camera it alerts me, and shows the camera on the map. However when I browse the map they aren't visible.
It's important because every POI category you add seems to require additional processing power to display, if you have the 13 or so categories for speed cameras it can slow the refresh down quite significantly. This way I don't have any POI's enabled at all and it all runs along nice and smoothly Smile
geedee
PostPosted: Mon Aug 15, 2005 11:43 am    Post subject: Reply with quote
Thanks all.
both ways work well, but is it possible to have "voice" warnings on TT5 mobile.
Graham
flasher
PostPosted: Mon Aug 15, 2005 11:52 am    Post subject: Reply with quote
the answer to the warning sounds is here
http://www.pocketgpsworld.com/tomtom-poi-alerts.php
iPhone 3Gs 32GB
geedee
PostPosted: Mon Aug 15, 2005 1:06 pm    Post subject: Reply with quote
Thanks Flasher
Graham
23.012 (08 Jan 25)
