Pocket GPS World :: View topic - Tom Tom Go in Ford with Quikclear windscreen??????
vantheman
PostPosted: Thu Aug 11, 2005 7:36 pm    Post subject: Tom Tom Go in Ford with Quikclear windscreen?????? Reply with quote
Anyone actually sucessfully using a new Tom Tom Go unit in a Ford with their electrically heated Quikclear windscreen. Read lots about them not working but also found almost as much conflicting info saying that they work fine....... confused Confused [/img]
EQtomtom300
PostPosted: Thu Aug 11, 2005 8:49 pm    Post subject: Reply with quote
Hi Mate,
Mine works in a focus no problems.
AFAIK its the althermic windows that are in certain European cars that the problems start ie later Renaults,Citroens etc.
If you search around on here someone will have posted a list i'm sure.
EQ
Pocketgps
PostPosted: Thu Aug 11, 2005 9:06 pm    Post subject: Reply with quote
My Mio168 works fine in my mates Mondeo which has a heated front screen.
PostPosted: Thu Aug 11, 2005 9:33 pm    Post subject: Reply with quote
And no problems in my Discovery which has a heated front screen.
vantheman
PostPosted: Thu Aug 11, 2005 11:55 pm    Post subject: Reply with quote
Thanks all that's really usefull, I know what I'll be buying this weekend :D
JAWS1975
PostPosted: Fri Aug 12, 2005 1:07 pm    Post subject: Reply with quote
I HAVE A 52 PLATE GALAXY WITH WITH 5 GPS UNITS ALL WORK FINE 10/10
Bobm
PostPosted: Fri Aug 12, 2005 1:49 pm    Post subject: Reply with quote
Oh dear I seem to buck the trend. When my Tom Tom 500 was mounted on velcro on the right hand side of the dashboard in my Ford Focus it worked fine. When I got the Brodit mounting kit which placed the unit below the level of the windscreen I had frequent problems getting a fix. This was solved by the external aerial..which I placed in the right hand corner of the dashboard where the unit had sit previously. Now get very reliable fixes.
PostPosted: Fri Aug 12, 2005 1:52 pm    Post subject: Reply with quote
That's more likely to have occurred because you had the GO in a position where it could not obtain a decent sky view, that's not related to the heated screen itself though.
Antoeknee
PostPosted: Fri Aug 12, 2005 6:32 pm    Post subject: Reply with quote
I have a Mondeo with heated screen.
When mounted in central position TT will maintain sat fix 98% of time, if the signal is marginal due tall buildings, trees etc. then it can lose the fix.
Never happens in wifes Fiesta (no heated screen).
Mounting TT close to pillar on either side of screen seems to cure this problem.
EQtomtom300
PostPosted: Fri Aug 12, 2005 9:09 pm    Post subject: Reply with quote
I too have a brodit mount for my TT300. I placed mine to the left of the wheel, just above the right hand corner of the stereo, same place as yours??
Mine works perfectly haven't had any problems at all yet, touch wood.
Eq
Bobm
PostPosted: Sat Aug 13, 2005 10:27 pm    Post subject: Reply with quote
Eq
Yes that's the spot - just over the driver's central airvent. Fixes became very erratic until I got the external aerial. As was mentioned above this may well have been down to lack of sky but it was noticeable how much the signal strength dropped even though you could still see the unit when standing at the front of the vehicle looking over the bonnet or looking down from above.
Unplugged
PostPosted: Sun Aug 14, 2005 12:19 am    Post subject: Reply with quote
My fiesta has a heated screen and ive no problem with the GPS. I have mine mounted to the far right so its by the steering wheel so theres an area of screen there thats clear of the heating elemetns anyway but even center screen it works flawlessly.
tomtomgone
PostPosted: Sun Aug 14, 2005 7:55 pm    Post subject: Reply with quote
Hi, I have tried mine in a mondeo & fiesta with heated screens, and whilst i can get a signal in the corner, i found if you look at the sat screen, its a pretty weak frantic signal usually only 3-5 sats half strength. After buying the antenna, all the sats are full strength and usually get 9-10 sats locked, sometimes 11.
I was ok with the weak signal like everyone else, but when I started driving through trees or tall buildings the TTG went mad! So decided to get the antenna, and certainly dont regret it!
Unplugged
PostPosted: Mon Aug 15, 2005 1:28 am    Post subject: Reply with quote
Hmmm cant say ive rearlly noticed that I get 6 or 7 sats but still adds up to full signal.
Not enougth to justify paying out £50 for an ext areil
22.062 (12 Jun 24)
