Snaggle Occasional Visitor
Posted: Wed Jul 06, 2005 10:03 pm Post subject: POI camera database for Navigon 5? |
Does the camera database work for navigon 5 or is there one available for it ?
TIA
Snaggle |
Pocketgps Lifetime Member
![](modules/Forums/images/avatars/gallery/1_navigon_7110.jpg)
Joined: Nov 16, 2004 Posts: 2145 Location: Midlands, UK
Posted: Wed Jul 06, 2005 10:13 pm Post subject: |
You can use the free Safety Camera files from this web site but you will need to purchase POI-Warner, but if you had version 4 and purchased POI-Warner for that then the upgrade is free.
Purchase new route - approx 30 Euros:
http://www.navigating.de/MN5_en/POI/Index.htm
Upgrade for free route:
http://www.navigating.de/MN5_en/POI/Upgrade/Upgrade.htm
As far as I know there are no free programs that work with Navigon.
If you get POI-Warner you could then follow the guide on my web site by clicking the link at the very bottom of this post, then proceed from after installing POI-Warner. |
sl_uk1 Occasional Visitor
Posted: Thu Jul 07, 2005 9:09 am Post subject: |
I have the spv m 2000, i am using navigation 5 bluetooth, i understood that it came with the speed camera database, i know it can be downloaded for free from here but does thatw ork on the spv m 2000. i note there have been some posts about requiring points of interest.
The navigation 5 has points of interest and the warnings, does anyone know how to instal the free pocket gps cameras on navigation 5
many thanks
steven |
Monaco Occasional Visitor
Posted: Fri Aug 05, 2005 11:23 pm Post subject: |
The instructions for loading speed camera POI onto my Mio 168 running MN5 were perfect. Many thanks for taking the trouble to do these as there is no way I would have worked it out.
regards
Daren |
StrongGale Occasional Visitor
Posted: Fri Aug 12, 2005 1:13 am Post subject: |
Has anyone got instructions for loading the Safety Camera Database using POI-Warner and Navigon MN5? I can find them for Tom-Tom but not for Navigon MN5.
Cheers! SG |
chris_w Pocket GPS Verifier
![Pocket GPS Verifier Pocket GPS Verifier](modules/Forums/images/ranks/verifier.gif)
![](modules/Forums/images/avatars/gallery/avatar_anime_072.jpg)
Joined: Nov 09, 2004 Posts: 628 Location: West Yorkshire
Posted: Fri Aug 12, 2005 10:25 am Post subject: |
you'll need to download POI Sync from this website.
Then open the files up in POI Sync and "Save As" an .asc file with EXACTLY the same name as the original .ov2.
Then copy the .asc file and the associated orginal .bmp file onto you PDA and activate them in POI Warner..
hope this helps. _________________ Thanks,
Chris |
Posted: Fri Aug 12, 2005 1:45 pm Post subject: |
Thanks for the advice, I'll give it a try.
Cheers! sg |
Posted: Sat Aug 13, 2005 6:42 pm Post subject: |
I must be being a bit thick, as I can't work this out.
I've downloaded PoiEdit and selected 19 of the files from the PocketGPS Safety Database. I've saved these with .asc extension (general ascii) and exported them all the HD of my pc, so I have a directly full of .asc & bmp files.
This is where I get stuck!
I have copied the files to the PPC and put them in the pois directory under POI-Warner, but I can't work out how to load these in POI-Warner. When I go into POI-Warner and choose POI-Sync, POI-Selection, the only sites that it shows me are www.poihandler.com and www.pocketnavigation.de, neither of which I'm too bothered about using!
The instructions for POI-Warner are about as clear as mud???
Any help is most appreciated.
Cheers, SG |
Posted: Sat Aug 13, 2005 7:07 pm Post subject: |
Ignore my last message, think I might have cracked it after all...
Cheers! SG |
Posted: Sat Aug 13, 2005 7:35 pm Post subject: |
Let me know if you are stil struggling. _________________ Thanks,
Chris |
Posted: Tue Aug 30, 2005 4:39 pm Post subject: |
Thanks for all of your help, got it working a treat now!
Cheers! SG |
chris123 Regular Visitor
Posted: Sun Sep 11, 2005 12:20 pm Post subject: |
Silly question,
Is there any difference between the *.asc files created via POIEdit and the *.asc files that are included as standard in the pocket gps database zip file? I have been creating asc files for my gf's dad for the past few months (for him to use with Navigon 5 and POI Warner), until it occurred to me that I may be over complicating things?
Chris _________________ HP 614c
McGuider 7.54
Memory Map
PocketGPS speed camera database |
