mikeeee Occasional Visitor
Posted: Fri Aug 05, 2005 7:48 pm Post subject: Tom Tom 5 maps will not load |
I have used a Mitac with tt3 for the last 6 months with no snags. However when upgrading to ttn5 I can load the software, however when I insert the maps CD I get a message "not enough free space on temproary folder - cannot run setup"
It does not seem to be a PC problem as I can run and install the maps from ttn3. The temporary folder exists on the pda, and is empty. However the software does not seem to notice this.
I have ditched everything on the pda and started from scratch, however the same problem keeps coming up.
If anyone out there can help I would really appreciate it.
Mikeeee |
Posted: Fri Aug 05, 2005 8:09 pm Post subject: |
Use a card reader to load the maps - its much faster and then you can select the exact directory you want the map to install to - you have probably by accident tried to install in excess of 100MB of map to a device that has far less memory than that required - mike |
SRS Occasional Visitor
![](modules/Forums/images/avatars/3104050844236bf1e6e8c1.jpg)
Posted: Fri Aug 05, 2005 9:32 pm Post subject: |
This is actually a known problem with TTN5. Their suggested workaround is to copy the entire contents of the CD into a folder on your Hard Disk and then run setup from there.
I think they try to use the current folder as temporary space and of course that doesn't work too well on a CD-ROM.
Slider. _________________ HTC TyTN II Windows Mobile 6
TomTom Navigator 7.450(9028)
UK & ROI Map V720.1802 |
Posted: Sat Aug 06, 2005 9:37 am Post subject: |
Slider,
Thanks for your advice. I will give it a go.
Mikeeee ![Laughing](modules/Forums/images/smiles/icon_lol.gif) |
g0avo Occasional Visitor
Posted: Sat Aug 06, 2005 2:18 pm Post subject: TomTOm Not enough space in temp folder cannot run set-up |
This is a common problem - if you go to the TomTom sight it will tell you how to remedy this problem - It is VERY easy to fix.
I had the same problem myself and could not find a solution on this forum.
Paul g0avo
http://www.tomtom.com/3239 |
Posted: Sat Aug 06, 2005 2:24 pm Post subject: TomTOm Not enough space in temp folder cannot run set-up |
This is a common problem - if you go to the TomTom siite it will tell you how to remedy this problem - It is VERY easy to fix.
Paul g0avo
Posted: Sat Aug 06, 2005 6:42 pm Post subject: |
Guys,
Thanks for your help, Slider was right and I now have the system up and running, if only I could sort on those POIs.......
Thanks to all
Mikeeee :D |
Posted: Sat Aug 06, 2005 7:23 pm Post subject: |
Whats the problem you are experiancing with the POI - give more details and no doubt there will be help avail - Mike |
jeff261159 Occasional Visitor
Joined: Aug 08, 2005 Posts: 30 Location: Portsmouth, Hamphire
Posted: Mon Aug 08, 2005 3:31 pm Post subject: Installation Error |
The easiest way to get round this is remove the cd from the drive, then go to 'run' then type in %temp% delete the 'setup' file (tomtom) from this list using the delete button on your keyboard, once done you will be able to install the maps. |
mburton2 Regular Visitor
![](modules/Forums/images/avatars/gallery/avatar_ani_005.gif)
Posted: Wed Aug 10, 2005 11:06 am Post subject: Re: Installation Error |
jeff261159 wrote: | The easiest way to get round this is remove the cd from the drive, then go to 'run' then type in %temp% delete the 'setup' file (tomtom) from this list using the delete button on your keyboard, once done you will be able to install the maps. |
I was JUST about to suggest that!........Worked for me! ![Thumbs Up](modules/Forums/images/smiles/custom2.gif) |
