bezste Occasional Visitor
Posted: Wed Jul 20, 2005 8:58 pm Post subject: Favourites keep disappearing!! |
Hi, searched the forum for this answer but only found a reference to a possible bug but no solution.
I have a Medion MDPPC250 running Tomtom 5. Every time I start up the PDA my favourites (and home location) have disappeared
Am I missing a folder?
I'm new to PDAs and GPS so go easy on me guys! |
linknet Frequent Visitor
Posted: Wed Jul 20, 2005 9:22 pm Post subject: |
The favourites are stored in the Great_Britain-Map.cfg file on the memory card (or correspondingly named file if you are using a different map).
First check if you are using an SD card that it is unlocked.
Secondly check that the .cfg file is not read only.
Roger |
Posted: Thu Jul 21, 2005 10:15 am Post subject: |
Spot on Roger! The file was indeed set to read-only.
Changed its properties and now I'm a happy bunny :D
Many thanks
Steve |
Royston Regular Visitor
Joined: 20/05/2003 21:40:29 Posts: 90 Location: United Kingdom
Posted: Mon Jul 25, 2005 2:39 pm Post subject: Favourites keep disappearing!! |
Had the same problem, just lost the favourites. Looked on the SD card in the .cfg file and it was ok (ie) was not set to read only. Also, the sd card was unlocked. So, did an active sync restore with the sd card in the pda and everything is ok now. Didn't think a restore was able to alter anything on my sd card!!...strange.
Ipaq 3870
polstar gps (fast pickup tt5.01) |
Posted: Tue Jul 26, 2005 8:03 pm Post subject: |
YEP.....lost favourites etc because I changed countries and then returned to GB map......seems like a bug others have had. Anyway the sd card files were ok and now I see why a restore was needed to get these 'greyed out' icons back to normal.
Ipaq 3870
polstar bt |
shrubies Occasional Visitor
Posted: Tue Jul 26, 2005 9:45 pm Post subject: Favourites keep disappearing!! |
One suggestion is to download the laset version of poiedit http://www.poiedit.com/index.htm, as you can import the map CFG file into it and create a POI from it. |
TuurG Frequent Visitor
Joined: Nov 23, 2004 Posts: 454 Location: Haarlem, The Netherlands
Posted: Tue Jul 26, 2005 11:32 pm Post subject: |
Royston wrote: | YEP.....lost favourites etc because I changed countries and then returned to GB map......seems like a bug others have had. Anyway the sd card files were ok and now I see why a restore was needed to get these 'greyed out' icons back to normal.
Ipaq 3870
polstar bt |
Doesn't seem a bug to me. Favourites etc. are stored in your map settings. So if you switch maps, yuo will have different favourites. If favourites are not set yet in this new map, it seems your favourites are lost. But actually they are in the other map. |
villaman Occasional Visitor
Posted: Mon Aug 08, 2005 2:14 pm Post subject: |
Some great gen here but I can't find a .cfg file in the map on my SD card. There are several Great-Britian-Map files but none with a config extension.
Help please. |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10644 Location: Suffolk, UK
Posted: Mon Aug 08, 2005 6:52 pm Post subject: |
It could be that you have 'hide extensions for known file types' ticked in Folder Options.
If you Right Click each of the Great-Britian-Map files you have, the Properties will tell you what type of file it is. _________________ Richard
TT Via 135 App 12.075: Europe Map v1145 |
PAQMAN Regular Visitor
Posted: Mon Aug 08, 2005 9:37 pm Post subject: |
It is there, its Great-Britain but the extension is truncated if you are looking for it via the PDA File Explorer, if you explore from MS Active Sync you will see the full name and then its easy to identify. |
mikeiow Occasional Visitor
Posted: Mon Aug 08, 2005 11:26 pm Post subject: |
Same problem, mine is 'greyed out' as read-only and archive but how to I change the permissions ? I wouldn't think I want to restore it, surely !?
thanks
Mike |
Posted: Tue Aug 09, 2005 7:16 am Post subject: |
You copy the .cfg to the PC and delete the original on the card.
Right Click the .cfg file on PC and choose Properties. Untick the Read Only option at the bottom, and OK out.
Copy the .cfg file back to it's original location, in the Map Folder. _________________ Richard
