40apple40 Occasional Visitor
Posted: Sun Aug 07, 2005 12:53 am Post subject: TT go 300 wont show up on pc...please help. |
when i plug my unit into my pc (with XP Pro) via usb it comes up with the autoplay search. this takes ages - about 5 minutes - & it wont let me cancel it like it should. once it's finished when i select "my computer", the "my computer" window is blank instead of showing all the drives - C drive, D drive etc, so i cant access my tom tom go 300.
Also i then can't close the "my computer" window.
i've tried reseting the restore point to a few days earlier on the pc but it still happens.
The unit worked fine originally & showed up as a removable storage device.
what can i do so it just shows up as a removeable device again?
thanks,
apple |
alix776 Pocket GPS Moderator
Posted: Sun Aug 07, 2005 12:56 am Post subject: |
i think it should show up as removable device shoulodnt it can you access the sd card at all _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
Posted: Sun Aug 07, 2005 1:13 am Post subject: |
it showed up as a removable device when i first tried it a few days ago but now the "my computer " window is just blank , so it doesn't show up at all.
also the "my computer" window wont close down so it seems to have made the pc hang.
apple |
rayflan Frequent Visitor
Posted: Sun Aug 07, 2005 4:39 am Post subject: |
Without the go plugged into your pc is "My Computer" ok ?
Do your other usb devices work ok ?
Is it plugged into a usb hub ? _________________ Ray
New Url www.tomtomsatnav.info
Visit my site |
Posted: Sun Aug 07, 2005 8:20 am Post subject: |
"my computer" works fine when the TTG is unplugged from the pc.
my mp3 player works fine when plugged into usb & shows up as a mass storage device as it should.
I'm not using a hub - it's being plugged straight into my pc - i have also tried different ports & get the same result.
apple. |
rkm_hm Frequent Visitor
Joined: Nov 28, 2004 Posts: 532 Location: Warwick, UK
Ugly-Kid-Joe Occasional Visitor
Posted: Mon Aug 08, 2005 12:53 pm Post subject: |
It may be due to any Antivirus or firewall software running. I had this problem, but when the software was stopped the go would be reconised. |
Posted: Mon Aug 08, 2005 9:47 pm Post subject: |
the thing is it was working fine. i put the speed camera & voices for cameras on it & all was still fine.
i dont know why it would suddenly not work.
the TTG is recognised , but the autoplay thing starts & never finishes - it does seem to fine the required files on the card.
if i put a new SD card in it's fine, so it must be the card & not the TTG.
any one know how Tom Tom are about guaranteeing cards that have had stuff added to them?
any more ideas would be gratefully accepted. |
Posted: Mon Aug 08, 2005 10:32 pm Post subject: |
Can’t see there being a problem- after all tomtom changed the original application so that custom pois could be added.
Had a problem a while ago pc couldn't find the tomtom at all. I tried other ports and other removable drives worked ok, solved problem by deleting usb ports in control panel, rebooted and let windows reinstall them. Might be worth a try _________________ Ray
Visit my site |
Posted: Mon Aug 08, 2005 10:46 pm Post subject: |
Had a problem a while ago pc couldn't find the tomtom at all. I tried other ports and other removable drives worked ok, solved problem by deleting usb ports in control panel, rebooted and let windows reinstall them. Might be worth a try[/quote]
the thing is it works fine with another SD card so the drivers & pc settings are all good.
apple |
Posted: Thu Aug 11, 2005 11:07 pm Post subject: |
yes i have a back up - but i cant do anything with the card as the pc wont see it - thats the whole problem - i cant access the card on the pc, it actually works ok in the TTG.
apple. |
sgould Frequent Visitor
Posted: Thu Aug 11, 2005 11:12 pm Post subject: |
There have been some oddities like this on the 700. It seems that the USB lead needed a harder push into the back of the GO. Maybe something similar?
Or try a different lead. _________________ TTGO 700 (dead)
iPhone 3GS + TT holder
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
Kenwood DNX-4210DAB with Garmin maps |
dill Regular Visitor
Posted: Fri Aug 12, 2005 7:01 pm Post subject: |
My laptop only see the 500 if I switch on TomTom Go then plug in the usb cable.
Dill |
