bobulos Occasional Visitor
Joined: 11/08/2003 11:30:36 Posts: 16 Location: United Kingdom
Posted: Fri Jul 29, 2005 12:00 pm Post subject: TomTom 5 on Tungsten E |
Does anyone know the minimum palm os required for TomTom5?
I am unable to run TomTom5 on my Tungsten E. I copy all the required files to the SD Card but when you get past the voice selection screen it just exits.
Any ideas would be appreciated. |
jcw1017 Occasional Visitor
Posted: Sun Aug 07, 2005 8:06 pm Post subject: |
I have the same problem. I got my TT5 on Thursday and have had zero luck with it. Any new info? |
TazUk Regular Visitor
![](http://www.hardwareuk.myby.co.uk/avatar/floyd/14.jpg)
Posted: Sun Aug 07, 2005 10:33 pm Post subject: Re: TomTom 5 on Tungsten E |
bobulos wrote: | Does anyone know the minimum palm os required for TomTom5? |
Well the Tungsten C is on the approved list and that runs PalmOS 5.2.1, which is the same as the Tungsten E ![Confused](modules/Forums/images/smiles/icon_confused.gif) |
Posted: Mon Aug 08, 2005 11:29 am Post subject: |
I have just installed TT5 on a clie TJ35 and it works great.
The Tungstens OS is Palm OS 5.2.1.
The TH35 Clies OS is 5.2.1.
Its the same os so TT5 should work on both ? Only difference is the clie uses a memory stick and the Palm uses an SD card, I can't see this being an issue.
I have tried several times to run TT5 on the Tungsten E and have given up! |
WolfMax Occasional Visitor
Posted: Tue Sep 13, 2005 2:43 pm Post subject: |
It could be that TomTom is looking for a Bluetooth system and can't find one. The wired system is not compatable with Palm and as we have already found, the palm program seems to be tailored differently to work on the Palm than it is to work on a PPC |
Posted: Wed Sep 14, 2005 10:50 am Post subject: |
WolfMax wrote: | The wired system is not compatable with Palm |
Not completely correct.
What I meant is the E can't use a cable GPS so TT5 wired version will not work with the E. Also the E has a different Palm OS5 version to that of the T3 and T5 but it is the bluetooth issue that I believe to be the problem |
BaggieBoy Lifetime Member
Posted: Thu Sep 15, 2005 1:00 pm Post subject: |
The "E" certainly can use a wired GPS, that's exactly what I use with Mapsonic. |
Posted: Thu Sep 15, 2005 11:23 pm Post subject: |
I think he means you can't use a wired GPS with TTN5 on a Palm ;) |
Posted: Tue Sep 20, 2005 3:44 pm Post subject: |
You can use TT5 with a wired GPS on a Palm as I have done so with many clies , it may just be a Tungsten E problem. |
MikeProcter Regular Visitor
Joined: Sep 24, 2004 Posts: 220 Location: Croydon, United Kingdom
Posted: Tue Sep 20, 2005 11:07 pm Post subject: |
I use a wired Holux GR213 with a Palm T3 & Tom Tom 5.12 with no problems.
Also I use the same wired receiver with a Treo 650 & 5.12 with no problems.
Maybe the E doesn't have enough memory? - is it 16MB? maybe it's another problem with the E. Tom Tom do not list it as being compatable. _________________ Skoda Columbus and for emergencies: TomTom + iPhone 4 & TomTom car kit |
Batchpad Occasional Visitor
Posted: Wed Oct 19, 2005 11:42 pm Post subject: |
I had exactly the same question about running TT5 on the Palm Tungsten E so I contacted TT direct. They advised that TT5 will not run on the E but didnt state the reason why.
I think the TT5 cabled version does not support Palm and the Palm version is looking for Bluetooth.
I installed Viamichelin's navigator 3.2 instead..!! |
Posted: Wed Oct 19, 2005 11:53 pm Post subject: |
My Palm version would be a 'bluetooth version' but I only use a wired receiver without any problems.
The lack of support is probably because TTN 5.12 is memory hungry & the Zire & E don't have enough memory.
My Treo has 23 approx mb available ex factory & has 14mb free as I run it, but when running ttn there is only 1-2 mb free. _________________ Skoda Columbus and for emergencies: TomTom + iPhone 4 & TomTom car kit |
