daz3215 Occasional Visitor
Posted: Sun Aug 07, 2005 12:07 am Post subject: help!!!! |
can you help me im tying upload the speed camera software into my navman 510 and its coming up with this (no pois found in input file) what does this mean? does it mean i cant have speed cameras on the navman 510?
cheers
daz |
alix776 Pocket GPS Moderator
Posted: Sun Aug 07, 2005 12:20 am Post subject: |
have a read of this link http://www.pocketgpsworld.com/uksafetycameras-navman.php _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
Posted: Sun Aug 07, 2005 12:31 am Post subject: |
yeh i went through all that and at the end of it my computer came up with this (no pois found in input file) dont know why
thanks anyway |
Posted: Sun Aug 07, 2005 12:47 am Post subject: |
sorry ive not got an icn to play with but give it a day or so and im sure youll have an answer did you follow the procedure exactly the pois should only be visible on your icn i think there is a navman forum that maybe able to help but give it a day or so and im sure therell be more help _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
banger9365 Lifetime Member
![](modules/Forums/images/avatars/gallery/avatar_ani_015.gif)
Posted: Sun Aug 07, 2005 1:24 am Post subject: |
no pois found in input file is down to the fact you have got the wrong file format ,find the file that says csv files and open and now the other file (yes otherfile) now open pocketgps_continental with NOTEPAD and now put ; infront off Longitude,Latitude,Name so it look like ;Longitude,Latitude,Name and now close and save you will have a working file for the navman |
Withome Occasional Visitor
![](modules/Forums/images/avatars/gallery/avatar_ani_013.gif)
Posted: Wed Aug 10, 2005 12:25 pm Post subject: |
If what is suggested above does not work, double check that you have properly extracted the files as per the instructions. I know that Windows XP lets you view and work with the files without actually extracting them. I was caught out by this first attempt but have had no problems since realising that you have to extract the files into a new file.
Hope that helps you or another user - even if it is just to make me feel better at failing to follow the instructions.
Mark |
