herc Occasional Visitor
Posted: Mon Jul 11, 2005 9:02 am Post subject: ICN 610 help |
A friend at work has recently purchased the navman 610 how do I add speed camera alerts for her>?
Also should I update her software if so where should I download these from.
Thnx in advance. |
Posted: Mon Jul 11, 2005 9:08 am Post subject: Re: ICN 610 help |
herc wrote: | A friend at work has recently purchased the navman 610 how do I add speed camera alerts for her>?
Thnx in advance. |
Instructions for loading the SC database are here and the downloads page for installing service packs is here. _________________ Tim |
Posted: Tue Jul 12, 2005 9:20 am Post subject: |
Tim I get the message after follwing your instructions saying no poi's to manage is this correct?? |
Posted: Tue Jul 12, 2005 9:38 am Post subject: |
herc wrote: | Tim I get the message after following your instructions saying NO poi's found in input file |
Posted: Tue Jul 12, 2005 9:53 am Post subject: |
herc wrote: | Tim I get the message after follwing your instructions saying no poi's to manage is this correct?? |
I'm a bit puzzled. Which instructions have you followed? Have you actually transferred anything onto your 610? The 'No POIs to manage indicates that you have not, to me. _________________ Tim |
Posted: Tue Jul 12, 2005 8:56 pm Post subject: |
Is there a way of checking what has gone across to the sd card on the navman.
I used the send to device command. |
Posted: Tue Jul 12, 2005 9:37 pm Post subject: |
The 6xx series stores Custom POIs in Internal Memory, I think, not on the SD/MMC card. Any Custom POIs which are present will show in the MYPOI category if you've enabled it, and will be 'Manageable' by the POIEditor. _________________ Tim |
SANDMANBLACK Occasional Visitor
Posted: Wed Jul 13, 2005 7:15 pm Post subject: |
i had 2 take sd card out 2 load my speed camera locations,worked tidy then |
droseman Occasional Visitor
Posted: Fri Aug 05, 2005 6:09 pm Post subject: |
I read in the user manual for my 610 that you can only store 25 Custom POIs - if this is the case, surely that would make installing the speed camera database impossible?
Dave |
icsys Frequent Visitor
Joined: Feb 20, 2004 Posts: 1154 Location: South Lancashire, UK
Posted: Fri Aug 05, 2005 6:43 pm Post subject: |
That is 25 custom POI groups of which safety cameras is one group. _________________ Ian.
iPAQ 2210 | Navman 4100 BT Receiver
Navman iCN 635
TomTom GO
Anquet OS mapping
Posted: Sat Aug 06, 2005 9:08 pm Post subject: |
ok, that makes sense. Thanks |
Posted: Sun Aug 07, 2005 1:46 pm Post subject: |
In addition to the above, and to clarify a little more, if you install the single 'all camera' file it is one POI.
Installing all of the speed zoned camera files in order to have seperate icons for each speed, will take up 14 POI groups.
HTH _________________ Ian.
Navman iCN 635
TomTom GO
Anquet OS mapping
