Pocket GPS World :: View topic - Tom Tom and C550
Tom Tom and C550
pcb007
PostPosted: Wed Jul 20, 2005 10:56 pm    Post subject: Tom Tom and C550 Reply with quote
Hi, i have heard that Tom Tom 4 does not work on the SPV C550, but does anybody know if it works ok with Tom Tom 5?
carmex
PostPosted: Thu Jul 21, 2005 12:08 pm    Post subject: Reply with quote
It's not listed by TomTom as a supported device, and neither is the Qtek 8100 which is essentially the same SmartPhone - they have a different screen resolution to the C500, SP3 etc so perhaps it's going to take a patch to make it compatible at a later date?
Owen
Product Manager
www.globalpositioningsystems.co.uk
YooNoo LTD
owen.haigh@yoonoo.co.uk
www.globalpositioningsystems.co.uk - GPS System Specialists
pcb007
PostPosted: Sat Jul 23, 2005 3:33 pm    Post subject: Reply with quote
For anyone that is thinking of upgrading to the C550 just to let you know that Tom Tom does not work on it. Screen resolution is to big. As suggested a patch may become available, but knowing Tom Tom god only knows when that will be.
thunderz2000
PostPosted: Fri Aug 05, 2005 12:22 pm    Post subject: Reply with quote
i have it working on a c550. But u will need mobile registry editor...a strong heart and a few alterations later within the registry and tom tom runs fine at the moment on the c550. Temprarily until the patch appears
reagrds
PostPosted: Fri Aug 05, 2005 1:09 pm    Post subject: Reply with quote
Care to share details of what registry changes are required?
thunderz2000
PostPosted: Sat Aug 06, 2005 9:44 am    Post subject: registry changes Reply with quote
ok darren this is what you need to do
first off you need to have mobile registry editor on the phone.
or a decent registry editor.
1. Open the reg editor and go to HKLM and select drivers
2. Then select display and open that
3.Your are then faced with GPE open that
4. Then select Values from the menu and open it
5.select Logical pixels X
6. Select Value data and alter it to 138 select done
7. Select Logical pixels Y and also alter value data to 138
select done and switch off the phone
Restart the phone
You should now see useable menus not to different from before but now in the interim Tom Tom should be very useable
HOpe it works for you as it has for me
Regards
Hawk
pcb007
PostPosted: Sat Aug 13, 2005 1:54 pm    Post subject: Reply with quote
Hi i have tried out your changes but i keep getting Operation cannot be carried out, do u know y this is so?
Paul
pcb007
PostPosted: Tue Aug 16, 2005 8:53 am    Post subject: Reply with quote
Sorted it, phone had to be totally unlocked. Works a treat now, looks even better on the C550 then the C500 :D
dasut
PostPosted: Fri Aug 19, 2005 12:53 am    Post subject: Reply with quote
What do you mean by unlocking the phone?
Is that to all network Question
PostPosted: Fri Aug 19, 2005 8:49 am    Post subject: Reply with quote
No, he is referring to the 'Application Unlock' which is different.
pcb007
PostPosted: Fri Aug 19, 2005 8:50 am    Post subject: Reply with quote
No the phone has to be application unlocked. It seems to come preset with the ability to use some programs and not others. So it has t be application unlocked in order to be able to use the regsitry edit program, otherwise you cant change the values. The unlock is normally straight forward to do via the Orange Web site.
awarner
PostPosted: Fri Aug 19, 2005 10:56 am    Post subject: Reply with quote
Don't forget while this works, you are also turning the C550 into a C500 with a few extra buttons, also this will alter the display until you alter the registry again. So you would need to alter the registry back and forth every time to still get the best out of the phone and use TomTom as well.
This has been discussed in more detail here
http://www.modaco.com/C550_TomTom_FIX-t224265.html
Life's too fast can I get off and walk for a bit?
Microsoft MVP Mobile Devices
MoDaCo.com Staff Team Leader
dasut
PostPosted: Fri Aug 19, 2005 1:17 pm    Post subject: Reply with quote
Thanks.... got the application lock sorted...fairly quick and easy.
Which version of TomTom Mobile works on SPV C550.. Wink
PostPosted: Fri Aug 19, 2005 2:14 pm    Post subject: Reply with quote
Preferably the version you have bought. TomTom Mobile 5.
dasut
PostPosted: Fri Aug 19, 2005 10:00 pm    Post subject: Reply with quote
Yes...TomTom Mobile 5.000 does work. The version i have 8)
