Pocket GPS World :: View topic - POI Not Listed
POI Not Listed
lostthewill
PostPosted: Fri Aug 05, 2005 6:10 pm    Post subject: POI Not Listed Reply with quote
Have downloaded speed camera database and followed instructions to paste OV2 file into map folder but when I go into Manage POI the camera data is not listed. What should I do now - so near yet so far! Any help much appreciated.
PostPosted: Fri Aug 05, 2005 7:45 pm    Post subject: Reply with quote
Which vs of tt are you using - I will assume vs5 or 5,1 due to the terminology used, when you get to the "manage POI" screen select Enable/ disable POI (lower left unless you have messed with the menues) in there ALL the loaded POI's will be listed - put a check in the box next to each speed cam icon - note you also need to copy the .bmp files into the map folder or there will not be any icons visable, then select "warn when near POI" form the manage POI screen and set up each one on its own for the advanced warning you feel happy with - Mike
Oldboy
PostPosted: Fri Aug 05, 2005 8:48 pm    Post subject: Re: POI Not Listed Reply with quote
Also there is a limit as to how many POI categories TT will 'see'. V5 I believe has a limit of 40.
TT Via 135 App 12.075: Europe Map v1135
22.105 (30 Oct 24)
