pillhead Occasional Visitor
Posted: Mon Aug 01, 2005 9:29 pm Post subject: TomTom 5.1 with Dell X50v |
Okay, noticed a few people are having success with TomTom 5.1 and the Dell Axim x50v palm tops, however mine just keeps dropping out of the application randomly, after quite a short time.
Was wondering if there were any specific tips on making it work well? SHould I increase teh amount of memory available to programs as apposed to storage? ANything else I should check? |
Posted: Tue Aug 02, 2005 2:37 pm Post subject: |
Actually, could any x50v users confirm to me that they have been running TomTom 5.1 sucessfully for navigation? I'm using one of the PDAMODS cradles with the Fuzion GPS, maybe it is incompatible with this? ANyone else have this same configuration? |
mbailey3 Occasional Visitor
Posted: Tue Aug 02, 2005 8:56 pm Post subject: Re: TomTom 5.1 with Dell X50v |
pillhead wrote: | Okay, noticed a few people are having success with TomTom 5.1 and the Dell Axim x50v palm tops, however mine just keeps dropping out of the application randomly, after quite a short time.
I had the same problem. Remove all POI's and it should be OK.
Everytime I drove past my local Tesco's TTN5 dropped out. With all the POI's disabled everything is happy! |
Posted: Tue Aug 02, 2005 11:52 pm Post subject: Re: TomTom 5.1 with Dell X50v |
mbailey3 wrote: |
Ahh, thats a shame, think I would rather have TomTom in none VGA mode, perhaps running version 5.0 than lose POI's ![Question](modules/Forums/images/smiles/icon_question.gif) |
nigelw Occasional Visitor
Posted: Wed Aug 03, 2005 1:55 am Post subject: |
I've not had any problems since upgrading to 5.1.
The longest journey I've been on is around 1 1/2 hours. I've tested it for work and back many times (about 1/2 hour each way). I use a Fortuna ClipOn BT GPS unit.
I have all the CheckPOInt camera POIs installed and proximity warnings set. They are the only POIs I have enabled. It just works now. |
raptorheli2 Occasional Visitor
Posted: Wed Aug 03, 2005 5:19 pm Post subject: |
it's a well known fact that the POI's need to be disabled for the x50v (see aximsite.com). i just put tt5.1 on my x50v this morning so i haven't tested it as of yet. the way round it is to copy the poi.dat file from tt3 into the folder in tt5 and overwrite the one in there. that fixes this problem.
cheers |
linknet Frequent Visitor
Posted: Wed Aug 03, 2005 7:02 pm Post subject: |
Quote: | it's a well known fact that the POI's need to be disabled for the x50v |
It's also a well known fact that the POI's need to be disabled for the illegal versions of TTN5.
The legally registered versions do not appear to have this problem.
Roger |
Posted: Wed Aug 03, 2005 10:53 pm Post subject: |
5.1 seems to work fine in none VGA mode with the default 5.1 POI file, the missus has been to rubery so far, usually drops out well before then.
I'm just going to drive mine to bromsgrove, because this trip guarentees it to drop out.
My theory is that it must be something to do with something in the POI file in VGA mode only, I wonder what specific point of interest causes this, hmm. |
Posted: Fri Aug 05, 2005 8:42 am Post subject: |
well i have a legal version and mine drops out on the poi so bang goes that theory.
the fault is with the hi res screens (x50v vga). there is something about 640 pixels it doesn't like. 5.1 update should sort that. it didn't for me or a lot on the aximsite either. however it did fix the memory leak for me.
there is a hack on aximsite to get tomtom to think it's running on a normal qvga screen and hence fixing this problem. i just put the poi file onto mine and it seems to have worked.
cheers |
Lancaster Occasional Visitor
![](modules/Forums/images/avatars/125711919142ab06ebc9596.gif)
Posted: Fri Aug 05, 2005 9:27 am Post subject: |
raptorheli2 wrote: | well i have a legal version and mine drops out on the poi so bang goes that theory.
cheers |
I'm using 5.1 on an X50v with safety camera POI (from Pocketgpsworld), parking and cash machines and it works perfectly. All in VGA mode.
I did have all the usual problems with the original version, and 5.1 is still prone to directing me up a dirt track from time to time.
Martin |
Posted: Fri Aug 05, 2005 3:20 pm Post subject: |
the reason yours probably works is your not using the inbuilt poi's which is where the problem apparently lies.
cheers |
AlexandreUVa Occasional Visitor
Posted: Fri Aug 05, 2005 3:24 pm Post subject: |
I have the Tomtom 5 USA + 5.1 upgrade on my x50v.
No problem so far even with the built in POI.
When you are speaking about VGA, are you speaking about the normal use of the x50v? or using a tweak to make it into real vga? Thanks |
Posted: Fri Aug 05, 2005 8:20 pm Post subject: |
the x50v is using vga now. without getting technical about this. as far as tomtom is concerned it's running vga mode (4x qvga) and this is the resolution it pumps out. tomtom 5 had problems with vga so 5.1 was brought out to fix it. it appears to have fixed it but the poi problem is still there, in UK maps anyway.
the hack i refer to is to fool tomtom into thinking the x50v is running a qvga screen and hence not locking up.
cheers |
Posted: Sat Aug 06, 2005 6:17 pm Post subject: |
AlexandreUVa wrote: | I have the Tomtom 5 USA + 5.1 upgrade on my x50v.
I'm speaking about the normal use of the X50v. I gave up on the "True VGA" hacks a while ago as they screw up a few things, and you have to keep resetting between applications.
Martin |
rondha Occasional Visitor
Posted: Fri Aug 12, 2005 11:38 pm Post subject: |
Just to confirm. My (legal) TTN5 was updated 5.1 only solving VGA problem. While the POI.DAT (UK) is still in big problem. So I use previous version poi.dat (I lost a lot of poi categories). I must confess that TomTom suck, a waste of money in poi.dat TTN5. They should mention about this in their advertisement for ttn5, otherwise they're in breach the Sale of Goods Act (SGA) 1979 in UK. |
