PAQMAN Regular Visitor
Posted: Fri Aug 05, 2005 9:55 am Post subject: Hard reset |
Question, how do I do a "hard Reset" and what does it result in? |
xda Lifetime Member
Posted: Fri Aug 05, 2005 10:09 am Post subject: |
The proceedure depends on which PPC you have, that should be in the manual that came with the device.
It will reset the PPC to it's original out the box state. _________________ Graham.
Map: Europe V910.4892
Nokia 925 Windows 8 |
Posted: Fri Aug 05, 2005 10:35 am Post subject: |
Sorry its a Ipaq 3950 and as its not a new one I do not have a manual. If I do a "hard reset." what happens do I need to install just my programs or do I have to install operating system again? Its no big deal installing names addresses etc. And apert from a couple of games and Tom Tom theres nothing much on it. |
xda Lifetime Member
Posted: Fri Aug 05, 2005 3:41 pm Post subject: |
Don't know about the Ipaq, but just removing the battery if it's possible would cause a hard reset on replacing it.
The operating system will re-install itself to its default settings but you will need to re-install TomTom and any other applications you had previously installed. _________________ Graham.
Posted: Fri Aug 05, 2005 4:30 pm Post subject: |
To hard reset an ipaq usually involves pressing the "reset" button with the stylus whilst simultaniously pressing both the "calender" and "itask" buttons, (the two outboard buttons at the bottom of the device). once done there will be no display, you might have to press the reset button a second time - the OS will self load but any applications, appointments and settings will be lost - this puts the device back to when it came out of the box - hope thats of some use - cheers Mike |
doctomahawk Occasional Visitor
Posted: Mon Aug 08, 2005 3:46 pm Post subject: |
It takes 3 hands to do a hands to do a hard reset on the Ipaq. You can always download a handy utility called PHM Task Manager.
/http://www.phm.lu/Products/PocketPC/TaskMgr/
It makes any type of reset (Including Hard reset) easy and its free.
Good utility to have on the PPC anyways. _________________ Compaq IPAQ hx4700
TomTom Navigator 5.2 BT |
Posted: Tue Aug 09, 2005 8:21 pm Post subject: |
Cheers doc, sorted |
