Pocket GPS World :: View topic - Mapsonic 3.1 sync to TWO PCs - has Mapstore changed ??
jblackmore
PostPosted: Thu Aug 04, 2005 10:52 am    Post subject: Mapsonic 3.1 sync to TWO PCs - has Mapstore changed ?? Reply with quote
I finally decided to upgrade from 2.51 to 3.1, and so far I hate it but hopefully that will pass !!
I sync to two PCs, so does anyone know if I need to run the install again at home, or if only changes are on PDA side ??
Also, why does it take 20 seconds to search for POIs everywhere when I only have three (I have A-Faves as a POI type and set these up for the next couple of journeys) ??
Cob
PostPosted: Fri Aug 05, 2005 9:41 am    Post subject: Reply with quote
I think if you have a large map (whole UK for instance) and you don't narrow down the search to a region, the search takes longer.
If the search is reduced to a county, the search is rapid.
22.094 (25 Sep 24)
