ren-o Occasional Visitor
Posted: Sun Jul 24, 2005 3:10 pm Post subject: Navman iCN 610 |
Hi to you all,
I have just purchased a Navman iCN 610. I have only set two routes one to work and one to home. When on the journey to work, the signal is only found after I have travelled some 28-32 miles, however, on the journey home the signal is found OK.
My second point is I have Safety camera software from the site, I have a problem of getting it to download into my POI file on the Navman.
I really need some help with these two problems as I really don't want to send the unit back.
If you can help I would really appreciate it.
Thanks for taking the time out to read this posting.
Best regards Ron |
![](modules/Forums/images/avatars/483587116439494e7a5e13.jpg)
Posted: Sun Jul 24, 2005 3:56 pm Post subject: |
With your first problem, what sort of view of the sky do you have when the car is parked at work and at home? If at home your car is hidden from half the sky by your house, garage, trees etc. then it will take longer to get a fix than from an open carpark, for instance. It is recommended that you obtain a fix before moving off, as getting a fix is much quicker in a stationary position.
You will have to provide more details for assistance with your second problem. Which files are you using (directory, file extension) and what are you using to edit the files for use with SmartST? _________________ Tim |
Posted: Sun Jul 24, 2005 4:37 pm Post subject: Navman iCN 610 |
Dear Tim, thank you for your prompt response.
First, my car is parked off road on a small car park.There are no garages, trees etc, to block the view of the sky. I have had only one morning were I got a fix.
Secondly, I have used the software from http://pocketgpsworld.com/uksafetycameras.php
Navman SmartST
SmartST V3
Am I using the correct software? I am only guessing.
Thanks again
Best regards Ron |
Posted: Sun Jul 24, 2005 5:34 pm Post subject: |
Hi Ron,
Within the camera file you've downloaded are various files. You need to read the instructions here. They are a bit out of date as far as the filenames go, but you need the .csv files in the \Other directory. _________________ Tim |
Posted: Sun Jul 24, 2005 5:52 pm Post subject: |
Thanks Tim,
I did all of that, when it was time to transfer the file to my GPS, a box apeared on my laptop, and told me that there was no file in my POI on the Navman.
As I am new to all of this I had my son who is a computer technician of some 10 years to install it for me,he had no success either.
Thank you for your time and efforts in helping to resolve this problem.
BEST REGARDS
RON |
Posted: Sun Jul 24, 2005 6:06 pm Post subject: |
Generally you get that message if you've edited the file using Excel instead of Notepad. _________________ Tim |
Andycambs Regular Visitor
![](modules/Forums/images/avatars/gallery/avatar_ani_042.gif)
Posted: Wed Aug 03, 2005 9:09 pm Post subject: Re: Navman iCN 610 |
ren-o wrote: |
Hi to you all,
Best regards Ron |
If you're having trouble with a signal - I purchased an external aerial for the Navman ICN 610 through EBay for under £20, and it made a phenomenal difference to the signal strength |
Posted: Fri Aug 05, 2005 2:34 am Post subject: iCN 610 |
Hi Andy,
Thanks for your help, you are right of course, I think I am just going to have to purchase an external aerial.
Best Regards Ron |
chas921 Regular Visitor
![](modules/Forums/images/avatars/gallery/avatar_ani_013.gif)
Posted: Fri Nov 11, 2005 8:05 pm Post subject: ren-o |
Ive managed to place the iCN610 into its cradle at the centre lower position of the windscreen below my Radar detector and managed to fold in the aerial? this caused a delay in capturing a satelite signal, so make sure the aerial is `open` and to avoid any obstruction to the antenna, the 610 is slightly offset now from the Radar detector.
Take care
Chas |
