TazUk Regular Visitor
Posted: Wed Aug 03, 2005 9:00 pm Post subject: TTN5 Palm - Duplicate files |
Hi, I've been having problems Hotsynching my PalmOne Treo 650, the cause of it appears to be duplicate files generated by TTN5. When I look on the internal memory I have several files with the same name, although the second version has capital letters whereas the first doesn't. So I have currentmap.dat and currentMap.dat. Hotsync seems to treat them as the same file so the first one gets backed up ok but when it comes to the second one it gives a Possible database overwrite problem. error. Renaming the files or deleting them has no effect, the first time TTN5 is run it creates currentmap.dat and the next time it creates currentMap.dat
Anyone else noticed this or have a cure? |
TuurG Frequent Visitor
Joined: Nov 23, 2004 Posts: 454 Location: Haarlem, The Netherlands
Posted: Wed Aug 03, 2005 10:03 pm Post subject: |
You should remove the one with mixed upper/lowercase, both from internal memory and backup folder.
You can also remove both, from both locations. It's an harmless file that is created again after selecting a map. |
Posted: Wed Aug 03, 2005 10:52 pm Post subject: |
TuurG wrote: | You should remove the one with mixed upper/lowercase, both from internal memory and backup folder. |
Tried that, it just gets re-created the next tim TTN5 is run
I have the same duplication with the GB map file. |
