Pocket GPS World :: View topic - BT-338 startup warning
josh71
PostPosted: Wed Aug 03, 2005 11:01 am    Post subject: BT-338 startup warning Reply with quote
I just warn you that BT-338 has a very long startup !! More than 5 minutes Sad After that, it will be fine.
I hate to start this device (in the morning).
I tried to cold start ... turn off / on ... no luck.
iankb
PostPosted: Wed Aug 03, 2005 3:43 pm    Post subject: Reply with quote
Mine usually starts up in around 20 seconds, and is a massive improvement over the 10 minutes or so for my previous Rikaline 6030. Maybe you have problems with your PDA's Bluetooth connection and/or your software client. I use mine with an iPaq H2210 and CoPilot. Do you leave it under a heat-resistant windscreen, because that can block the GPS signal.
Ian
iPaq 2210
Globalsat BT-338
Seidio G2500 Amplified Vent Mount
CoPilot 6, GPS Tuner 4.2, Navio 3.01
BMW 330ci Sport
cootuk
PostPosted: Wed Aug 03, 2005 6:13 pm    Post subject: Reply with quote
Perhaps you have a poor reception area....by my outside window or outside it takes about 50s, a couple of foot away by a PC and it takes 10mins.
Hooking it up to a PC by bluetooth with the appropriate software you can see what satellites it can lock, and they do vary quite considerably depending where you position the GPS
22.064 (26 Jun 24)
