Pocket GPS World :: View topic - pretec cf card and re-rad.antenna
footman
PostPosted: Sun Sep 14, 2003 8:04 am    Post subject: pretec cf card and re-rad.antenna Reply with quote
Ive read that to use a re-radiating antenna on a hand held GPS(such as my etrex legend)the gps unit should be shielded from picking up signal as this may"confuse"the signal from thr re-rad.I would like to use my re-rad with my new pretec cf gps(not LP).Bearing in mind what ive just written,is this possible,or would I have to buy pretecs own plug in antenna?
TIA
Laurence
You can use it with the Pretec Compact GPS. In most cases the signal coming from the re-rad is stronger than what it will pick up so it usually isn't too much of an issue. Sometimes it's better to have the GPS out of sight of the sky. Failing that the Pretec external antenna works well.
22.094 (25 Sep 24)
