Pocket GPS World :: View topic - navigon 5 - No longer supports TMC in UK
Goto page Previous  1, 2
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Traffic Message Channel (TMC)
chris_w
PostPosted: Thu Jul 28, 2005 11:22 am    Post subject: Reply with quote
I have a BIG problem with the way Navigon have handled this Evil or Very Mad
Anyway that won't get your problem solved.
First of all TMC for V4 is still working - checked today.
A few questions :-
1. Is the ariel damaged? if the TMC module is recognised and cycling through the stations it might just be the ariel. Is there any chance of trying a different Ariel?
2. Have you tried changing the GPS type in settings? I've had a similar problem - if you go into your GPS settings change it from "Navigon Modular" to "Navigon with TMC" or vice versa (make sure you save changes) and this may bring your TMC back - it's worked for me on a few occasions.
Hope this helps
Thanks,
Chris
Peppercorn
PostPosted: Sun Jul 31, 2005 9:52 pm    Post subject: MN4 and TMC Reply with quote
Again, many thanks for your reply. The antenna seems to be OK; I checked the resistance with an ohmmeter. The main setting right now says "Navigon with TMC". I will change that and see how it works.
chris_w
PostPosted: Mon Aug 01, 2005 12:21 pm    Post subject: Reply with quote
OK - I'd be interested to know if it works..............
Thanks,
Chris
Peppercorn
PostPosted: Tue Aug 02, 2005 9:45 pm    Post subject: MN4 and TMC Reply with quote
Chris,
I've just finished an extensive testing session. I have plugged the TMC receiver in and out, and tried all permutations of Navigon Modular and Navigon with TMC in the Settings menu, all with the same result: The TMC panel stays orange and the receiver seems to be cycling without hitting a valid station. I probably have a hardware failure and will contact Navigon to get that sorted.
chris_w
PostPosted: Tue Aug 02, 2005 11:43 pm    Post subject: Reply with quote
Sounds like it if non of that works - hope you get it fixed
Thanks,
Chris
ksistrunk
PostPosted: Mon Aug 22, 2005 2:31 pm    Post subject: Does Navigon MN5 TMC work in germany? Reply with quote
I need to know if Navigon MN5 1st of all has TMC, and secondly does it work in germany.
Please help. Thanks!!!!
chris_w
PostPosted: Mon Aug 22, 2005 2:42 pm    Post subject: Reply with quote
Navigon 5 does have TMC and it does work in Germany.
Check out www.navigon.com - this will give you more information
Hope this helps.
Thanks,
Chris
ksistrunk
PostPosted: Mon Aug 22, 2005 2:46 pm    Post subject: Reply with quote
wow that was a fast response. thanks. so i will get it then. I just got a gns 5840 gps/ rds /tmc receiver.
i hope it works good.
well see
chris_w
PostPosted: Mon Aug 22, 2005 4:36 pm    Post subject: Reply with quote
You didn't mention you had your own hardware Wink
You'll need the Navigon TMC Receiver for it to work with Navigon.
I don't believe that Navigon TMC will work with anything other than it's own hardware.
Best to check with them before you buy.
Thanks,
Chris
ksistrunk
PostPosted: Mon Aug 22, 2005 11:14 pm    Post subject: thats not what the manufactuer said Reply with quote
They said it works fine with navigon
it is the GNS 5840 receiver
chris_w
PostPosted: Mon Aug 22, 2005 11:20 pm    Post subject: Reply with quote
Go for it! - Glad it works Smile
Thanks,
Chris
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Traffic Message Channel (TMC) All times are GMT + 1 Hour
Page 2 of 2
23.012 (08 Jan 25)
