Pocket GPS World :: View topic - mio & tt5 using tomtom gps receiver option in tt5 softwa
bitsandpcsuk
PostPosted: Sun Jul 31, 2005 8:50 pm    Post subject: mio & tt5 using tomtom gps receiver option in tt5 softwa Reply with quote
when you setup the tt5 software for the first time, you have to configure the gps receiver. At first i was told to use the other cable nmea gps option, but since have changed it to think it is using the tomtom cable gps, which i find to be more accurrate and faster at finding the satelites at startup.
Does anyone have any more comments????
StevenGourlay
PostPosted: Tue Aug 02, 2005 7:07 pm    Post subject: Reply with quote
thats strange is that with the update installed.
Regards
Steven Gourlay
Bike Pics! Bike Chat! Visit-Ullapool
PostPosted: Tue Aug 02, 2005 7:36 pm    Post subject: Re: mio & tt5 using tomtom gps receiver option in tt5 so Reply with quote
Is this the Mio168? I doubt there is any real difference in performance, there is no difference between TomTom Cable GPS and Other Cable NMEA GPS aside from the fact that the TomTom entry auto configures the Port Speed to 38400. In real world using a receiver at a slower or faster port speed (if it supported different speeds) would not make any observable difference.
bitsandpcsuk
PostPosted: Tue Aug 02, 2005 7:45 pm    Post subject: Reply with quote
the software the mio 168 is running is version 5
StevenGourlay
PostPosted: Tue Aug 02, 2005 7:49 pm    Post subject: Reply with quote
sorry what i meant was did you use cabled nmea then installed the 5.01 update and changed to the tomtom GPS, as Darren says i would not think that you would see any major difference with what option you select as long as you select the correct com port.
Regards
Steven Gourlay
bitsandpcsuk
PostPosted: Tue Aug 02, 2005 8:22 pm    Post subject: Reply with quote
the mio 168 is only 2 months old I installed tt5 and used the cable nmea gps option on com 2 and noticed it took a while to find the satalites first thing each day and could not get any signal in the house at ALL, so playing around like you do I change to gps setting to tomtom cable gps.
Now it finds the satelites quicker, and works in the house at verious points.
StevenGourlay
PostPosted: Wed Aug 03, 2005 10:05 am    Post subject: Reply with quote
thats prob because you have been using it, when you first get a GPS it does take sometime to get a lock and the more you use the GPS the quicker it will get the lock.
Regards
Steven Gourlay
bitsandpcsuk
PostPosted: Wed Aug 03, 2005 7:49 pm    Post subject: Reply with quote
No
I had been using it on the cable nmea gps for a while b4 i changed it
razor69
PostPosted: Wed Aug 17, 2005 9:25 pm    Post subject: Reply with quote
hi all,
i have a mio 168 with tt5 loaded, but when i turn on tom tom and add a post code it says that there is no GPS device although i do have one on the back and it is flipped up,
what do i have to do to make it reconise the gps?
thanks
razor
PostPosted: Wed Aug 17, 2005 9:31 pm    Post subject: Reply with quote
Have you told TomTom what type of GPS you have? It's in 'Change preferences' 'GPS status' 'Configure'
Set it for 'Other cable NMEA GPS' Baud Rate 9600 & COM1
razor69
PostPosted: Wed Aug 17, 2005 9:43 pm    Post subject: Reply with quote
done that i now have the N E S W compass thing and a row of numbers at the bottom but at the top it still says No GPS device!
um what do i do now, have i got to go and stand in the street to get a good signal?
Razor
PostPosted: Wed Aug 17, 2005 9:50 pm    Post subject: Reply with quote
Well it ain't gonna work indoors unless you don't have a roof!
razor69
PostPosted: Wed Aug 17, 2005 9:53 pm    Post subject: Reply with quote
so what are you saying i should do then?
razor
as u can tell i am very new at all this
Pocketgps
PostPosted: Thu Aug 18, 2005 1:49 am    Post subject: Reply with quote
The settings for a Mio 168 running TT 5 (or) 5.1 should be
Baud Rate 4800
Serial Cable on SP2
The post above said that they where using TomTom Cable GPS, that can not be used on the Mio168, it just will not work at all, wrong baud rate, wrong COM port for the Mio 168.
Pc-Mobile
PostPosted: Thu Aug 18, 2005 3:11 am    Post subject: Reply with quote
A cabled GPS will work.
You can ignore the internal GPS as if it was not there.
Use com1 if you use external cabled GPS.
Pc-Mobile
http://pc-mobile.net/gps.htm
22.063 (19 Jun 24)
