Pocket GPS World :: View topic - LAND ROVER DISCOVERY HEATED SCREEN & TOM TOM 300?
strech
PostPosted: Sun Jul 31, 2005 9:05 pm    Post subject: LAND ROVER DISCOVERY HEATED SCREEN & TOM TOM 300? Reply with quote
Any one know if a tom tom 300 will work in a discovery 2 with heated front screen Laughing
any help guys
paul-pearson
PostPosted: Mon Aug 01, 2005 12:49 am    Post subject: Reply with quote
no landrovers come with this type of screen so you will be fine.
paul-pearson
PostPosted: Mon Aug 01, 2005 12:53 am    Post subject: Reply with quote
oh wait i didn't read your 1st coment right " heated front screen " i thought you meant reflective. i wouldn't have thought so you will probbably need the externall antenna.
sgould
PostPosted: Mon Aug 01, 2005 1:17 am    Post subject: Reply with quote
The GO seems to work OK in other Ford cars with the fine wires embedded in the screen. Does the Discovery have the same type?
The problem ones seem to be the coated windscreens that reflect heat. Mostly French.
TTGO 700 (dead)
iPhone 3GS + TT holder
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
Kenwood DNX-4210DAB with Garmin maps
strech
PostPosted: Mon Aug 01, 2005 4:02 pm    Post subject: LAND ROVER DISCOVERY HEATED SCREEN & TOM TOM 300? Reply with quote
yes it has the fine lines through the screen Laughing
stormstorr
PostPosted: Mon Aug 01, 2005 10:36 pm    Post subject: Reply with quote
Hi Strech,
I've had a classic and a 700 Go in my 2004 Discovery. I found that I could get a fairly good signal through the heated screen, but it did drop off regularly, and always at the wrong time! I cured this by fitting an external arieal kit. Ran it accross the dash, under the door seals and onto the shelf under the rear side window. Works a treat!
22.105 (30 Oct 24)
